Re: 440 Head Gasket Issue
[Re: dogdays]
#68599
06/06/08 11:53 AM
06/06/08 11:53 AM
Hell, just mark the spot and drill a hole through the gaskets you have. It have done it with the shim type gaskets before with no problems and I doubt you would have any with the FelPros. Just make sure to file off any burrs left behind before mounting the heads.
[Re: 2RTSE]
#68600
06/06/08 12:46 PM
06/06/08 12:46 PM
just built two motors and whent through the same thing i could not find any head gaskets with these holes so i punched them my self, word to the wise do not drill them make a punch and punch them on a block of wood, and by the way it will or should i say it has for me, keep your valve train cooler, which in turn, makes the motor run a little better, and helps keep the engine cooler as a whole. so in short form i can`t figure out why chrysler didn`t have these open from the factory either, but mine will be open from now on.
