440 Head Gasket Issue #68595
06/06/08 09:45 AM
06/06/08 09:45 AM
Clarkston, MI
2
2RTSE Offline OP
2RTSE  Offline OP
Clarkston, MI
I have a 1978 440 block with 346 heads and need advice/suggestions on what to do about the "extra" water passages they put in these heads.
I have read that these heads were used in RV's and Trucks and the extra water passages were added to cool the area near the spark plugs.
I cannot find a head gasket with the holes as shown in the pics. Can I drill holes in the head gasket to match? Does anyone know where I can get the gasket with all the holes? or, should I not worry about it and just cover up the holes with the standard gasket?
4471475-440-1 (95 downloads)
Re: 440 Head Gasket Issue [Re: 2RTSE] #68596
06/06/08 09:46 AM
06/06/08 09:46 AM
Clarkston, MI
2
2RTSE Offline OP
2RTSE  Offline OP
Clarkston, MI
2nd pic
4471476-440-2 (101 downloads)
Re: 440 Head Gasket Issue [Re: 2RTSE] #68597
06/06/08 09:59 AM
06/06/08 09:59 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
your pics aren't showing up .
theres some holes in the heads that the gaskets don't have , don't worry about them .
Re: 440 Head Gasket Issue [Re: JohnRR] #68598
06/06/08 11:36 AM
06/06/08 11:36 AM
dogdays Offline
dogdays  Offline
Just use the doggone gaskets. Disregard any old wives' tales about big block cooling holes.
R.
Re: 440 Head Gasket Issue [Re: dogdays] #68599
06/06/08 11:53 AM
06/06/08 11:53 AM
Hell, just mark the spot and drill a hole through the gaskets you have. It have done it with the shim type gaskets before with no problems and I doubt you would have any with the FelPros. Just make sure to file off any burrs left behind before mounting the heads.
Re: 440 Head Gasket Issue [Re: 2RTSE] #68600
06/06/08 12:46 PM
06/06/08 12:46 PM
just built two motors and whent through the same thing i could not find any head gaskets with these holes so i punched them my self, word to the wise do not drill them make a punch and punch them on a block of wood, and by the way it will or should i say it has for me, keep your valve train cooler, which in turn, makes the motor run a little better, and helps keep the engine cooler as a whole. so in short form i can`t figure out why chrysler didn`t have these open from the factory either, but mine will be open from now on.
Re: 440 Head Gasket Issue #68601
06/06/08 01:28 PM
06/06/08 01:28 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You can cover the holes with a standard gasket without any ill effects. However, the additional cooling is never a bad thing, so like was suggested, make the holes yourself. But if you feel that's sketchy, just throw the gaskets on as-is.
