1966 Dodge Coronet,318-2.Carter 2 barrel bbd series I believe.Took the carb off as I was doing some work on the motor.Figured while it was off I would clean and put new upper and lower gaskets on the carb.Well the shop where I went friday was closed,but thats another rant,so I figured I would put the carb back together just to get the car running and would go get my gaskets this week....Well as I was cranking the motor after a few seconds gas came out thru the acc.pump opening and thru the top of the carb and the middle section where the top bowl meets the middle.If I pump the acc.pump gas shoots thru the jets.Now when the carb was apart 2 things,Does the little ball bearing go in the bowl that the acc.pump sits in and not sure if this part came out or was just sitting on my bench.... Here is a pic of the carb and the part.It looks like a little metal clip.
Also,where can I find a detailed parts pic of the carb
