hey all,
I have very limited knowledge on auto repair, however i was going to attempt to fix my malfunctioning fuel gauge.
This thing will occasionally respond and the needle will go up , usually not all the way but even with a full tank, but at least like halfway or so, sometimes the thing doesnt respond at all.
The dash cluster is a little loose because one of the mounting bracket sites is busted off. A few times i was able to jostle the whole cluster and magically the gauge would perk up again.
Any ideas as to where i should start looking for this. I dont have a lift and dont know if you need to drop the tank to check the ground on the sending unit etc.
Is there a ground site on the cluster itself i should look for to see if the cluster is properly grounded???
any ideas on where to start with this gauge would be awesome, thanks.
