Page 6 of 7 1 2 3 4 5 6 7
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685543
05/12/10 10:59 AM
05/12/10 10:59 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Good Grief.
So many comments, so little information.
It's really quite simple:
Either coolant flow is adequate, or it isn't.
"Running something at 2-- degrees" and the engine's relative happiness or unhappiess doesn't account for where the temp is measured.
Does anyone believe that the location in the water pump where the sensor is located is the be all, end all?
It's not that a 440 "doesn't like" the temp being at
200-something degrees---they will, in fact, run hundreds of thousands of miles if the true coolant temp at the hottest point in the engine is 210 to 220. The problem is that the coolant temp isn't being measured at it's hottest point, and we don't know what it is at the hottest point when driving down the road.
What do all the gurus think the coolant temperature is in the middle of the cylinder head, where two exhaust valves are located right next to each other? How about inside the block, directly below that area? Here's a hint: It's a whole lot hotter than where the temp is measured at in the water pump!
The water pump housings in question sound screwed up to me, I either use stock ones or MP Aluminum.... but beyond that most of this discussion seems kinda hopeless....I mean...Older cars worn out at 70k miles? WTH does that have to do with a coolant temp discussion? My 176,000 mile '78 B body and my 210,000 mile '83 M body kinda kill that statement anyway. If all your stuff is worn out at 70k miles, you're doing something wrong
Rich H.
Esse Quam Videri
Re: Running hot with 440 source housing and pump [Re: ZIPPY] #685544
05/12/10 11:45 AM
05/12/10 11:45 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Good Grief.
Re: Running hot with 440 source housing and pump [Re: JohnRR] #685545
05/12/10 12:26 PM
05/12/10 12:26 PM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
Ok, so if my 383 starts running at 220+, measured in the same place that it currently runs 190-200 at the most, I guess I shouldn't be concerned????
Hogwash. Older engines aren't made to run at the same temps that modern ones are.
Yes, we are aware that the coolant runs MUCH hotter at the heads, that is not the point of that at all.
Re: Running hot with 440 source housing and pump [Re: DusterKrazy] #685546
05/12/10 04:07 PM
05/12/10 04:07 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I do not agree. I've never seen a 318 worn out at 70-80k miles, much less a /6. If they wore out it is simply because people did not take care of them
I found the claim rather amusing as well considering my Duster has a 318 with 119,000 miles on the clock and it runs great.
Under the work bench I have several 440 engines and most of them had over 100k on the clock too when they were pulled from cars several years ago.
Re: Running hot with 440 source housing and pump [Re: ZIPPY] #685547
05/13/10 06:13 AM
05/13/10 06:13 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
For what it's worth, I just got a CAT water pump for my 360 engine and it has an impeller designed for CCW rotation(looking at the pulley end.) If you spin an impeller backwards, it will pump fluid but at a reduced rate. I'll be sending this pump back. See the attachment. Maybe Doug is having the same problem?
Re: Running hot with 440 source housing and pump [Re: dmerc] #685548
06/24/10 09:47 PM
06/24/10 09:47 PM
Marcell, MN
68 Roadrunner Offline
Marcell, MN
I finally have run my new motor enough to say that I am having NO problems with my 440 Source housing & pump. I put in a 160 T-stat and the hottest I have seen it is 170.
1968 Roadrunner 383 auto .060 KB 400 domed pistons, Stealth heads, Torker intake, Holley 830, Lunati Voodoo cam 276/284, .513/.533, TCI 3500, 3.91 gears, all ARP fasteners,
Re: Running hot with 440 source housing and pump [Re: 68 Roadrunner] #685549
06/25/10 01:49 PM
06/25/10 01:49 PM
mr norms avenue
5571 Offline
5571  Offline
mr norms avenue
this was a great thread to read. My friends 440 daytona ran hot when he put a new pump on (think it was a 440source believe it or not), and when he went and talked to another daytona owner, who convinced him the stock pump is a better bet to get rebuilt (which he did), it ran cooler right away.
It always pays to check the fan clutch on high milege cars, I had a 395/425hp vette that is factory 11:1 compression. The new edlebrock water pump I put on that was not as good as the original one (rebuilt), it actually ran hotter. It did not move the water at idle like the factory pump, at all. Also, the fan clutch, was shot with the fluid that leaked out over time. I always vindicate looking at the fan clutch, like said on this thread.
Also, if your car is a high compression motor, I strongly recommend keeping the octane high. My vette runs great, if its largely on racing fuel. Nice and cool. If I ever put in 93 octane, if I have to cause it gets low, it wants to run hot, then overheats. With that car, the octane level makes all the difference. I also run it rich, to help keep it cool. A lean carb will come back and bite you with 10s of degrees on the temp guage. My friends daytona shed some temp when he added some octane booster.
my 2 cents. always rebuilt the factory pump first (do not assume new pumps are better than the factory pump), make sure the fan clutch locks up at temperature (and does not slip), and have the right fuel/octane and set the carb on the rich side.
67 hemi GTX silver 4spd, 70 cuda convert 340 4spd, 71 cuda 340 4spd (Curious Yellow, white billboards/interior), 70 Mr Norm's Challenger 440 4spd
Re: Running hot with 440 source housing and pump [Re: SomeCarGuy] #685550
06/25/10 04:00 PM
06/25/10 04:00 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
"hogwash" to comments that were never made, Oooo kay...
It's a free country, feel free to debate something that never existed
People are always looking for the cheapest possible thing they can get, but at the same time they just have to have the trick of the week because it makes their 3900lb car 8lbs lighter.
A stock 1969 iron housing from the junkyard will function properly, was made properly, and looks great after blasting and paint. If a person wants to cheap out, that's how to do it. Forget aluminum unless a little extra money is available for one well known to work properly.
Rich H.
Esse Quam Videri
Re: Running hot with 440 source housing and pump [Re: ZIPPY] #685551
06/25/10 05:24 PM
06/25/10 05:24 PM
Maryville tn
67coronetman Offline
Maryville tn
Well i am having the same problem getting hot.! i am going to take off that 440 source pump and put a stock one on asap.! and see how it does.!!
Old car are me......
Re: Running hot with 440 source housing and pump [Re: 67coronetman] #685552
06/25/10 06:25 PM
06/25/10 06:25 PM
dark side of the moon
Dougsmopars Offline OP
I put the high flow Milodon pump with there high flow stat temp droped 20 degree's.
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685553
07/16/10 10:41 PM
07/16/10 10:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
But according to some the hot water won't stay in the radiator long enough to get cooled off (horsefeather).
Lot's of shadetree comments, some grossly wrong, in this thread. 70-80k out of an old engine then it's junk, right. Sounds like that shadetree is missing a lot of leaves and someone got sun stroke there.
Don't be the exception.
Re: Running hot with 440 source housing and pump [Re: ZIPPY] #685554
07/17/10 12:34 AM
07/17/10 12:34 AM
Sorry Zip, you said this, so yes, the comment was made. Therefore, my comment in reply that an engine running hotter than before when measured in the same location was valid. It is perfectly fine to debate things. Here are your comments-
"The problem is that the coolant temp isn't being measured at it's hottest point, and we don't know what it is at the hottest point when driving down the road."
Re: Running hot with 440 source housing and pump [Re: SomeCarGuy] #685555
07/17/10 01:19 PM
07/17/10 01:19 PM
Tucson, AZ
Ramrod39 Online work
My New Title
Ramrod39  Online Work
My New Title
Tucson, AZ
I just pulled my receipts. I have the Mancini pump and housing. No problems with the Mancini pump?
Re: Running hot with 440 source housing and pump [Re: Ramrod39] #685556
07/17/10 03:09 PM
07/17/10 03:09 PM
Marcell, MN
Marcell, MN
Just thought I would give a quick update. Still no problems with my 440 source pump and housing. I have never seen the temp gauge over 190.
Re: Running hot with 440 source housing and pump [Re: JohnRR] #685557
07/18/10 09:05 AM
07/18/10 09:05 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Good Grief.
So many comments, so little information...
+1
This thread never should have run beyond 1 page...
Re: Running hot with 440 source housing and pump [Re: ZIPPY] #685558
07/18/10 11:33 AM
07/18/10 11:33 AM
I hate to hurt your feelings but i didn't buy the aluminum houseing to save weight in my 3900 lb car. My orignal houseing was damaged and i wanted a new one. Finding good used 40 year old parts is not easy in my area. No local yards still have any. They have all gone late model. New one was a phone call away. As far as i know there are no brand new cast iron ones out there. I suspose i could have left the car tied up for weeks waitting to find one on ebag and hope it wasn't damaged when it got here. Houseing was not replaced to save 8 pounds it was replaced to get the car back on the road. I'm happy that you have access to a large supply of good used parts for your 40 year old mopar but not everyone does.
Re: Running hot with 440 source housing and pump [Re: Supercuda] #685559
07/18/10 11:42 AM
07/18/10 11:42 AM
Shade tree ??? Sorry my friend but i've been in the auto business over 35 years. Not a back yard machinic. If you really beleive that motors from the 50's and 60's lasted as long as the new motors and being as trouble free then it shows who is under that shady tree. In the 70's garages did motor swaps weely. Ask your local garage how many motor swaps they do now. Ask your local yard how many motors they sold in the 70's every week and how many they sell now. Late model motors run 150 to 200,000 miles with no major repairs when maintained. 50's and 60's motors never did. Yes there were a few exceptions but not as a rule. It's a very well known fact in the industry that the late model motors are designed and built better then ever and last longer then ever.
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685560
07/18/10 03:28 PM
07/18/10 03:28 PM
Commando1 Offline
Commando1  Offline
I grant you that fact.
Hopefully, you'll you'll allow me to express something I believe in. It's a guess. No facts to back it up.
I feel if you take a good 60's - 70's engine, and, rebuild it using the best of today's components, it will last longer than today's overstressed (in my opinion) engines.
Also, take away the 'puter from today's engines, I feel, actually puts them at a disadvantage.
But again, I WILL grant you theyare seriously more efficient at extracting the last hp out of engines designed today. I just don't think they are "better". I really don't want a 3.sumthing engine putting out 500+ hp in my DD. I hate things run at 150% day in and day out. I feel safer crossing a bridge with a safety factor of 2 rather than one that has it's capacity at it's 150% physical limits. Yes the new bridge will work quite nicely. When new.
One last question to ponder, and maybe slightly OT, but what do you think an engine designed TODAY would look like if gasoline was still at $0.25/gallon (comparitively), and, let the marketplace drive design rather than federal regulators?.
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685561
07/18/10 04:10 PM
07/18/10 04:10 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Did you post a want ad, I must have at least 5 68-69 housings in the basement.
I replaced mine to save the weight , 8 lbs off the nose is 8 lbs off the nose ...
Re: Running hot with 440 source housing and pump [Re: Dougsmopars] #685562
07/18/10 09:21 PM
07/18/10 09:21 PM
808CUDA Offline
808CUDA  Offline
Thanks for the update Doug, I ordered my Milodon HV pump and stat today. I'll post my findings when I get it done.
