Re: Remove '70 slip-fit shifter handle.
[Re: W5Duster436]
#68536
06/06/08 02:20 PM
06/06/08 02:20 PM
Posts: 515 Dayton, Ohio
65cuda
mopar addict
mopar addict
Dayton, Ohio
are you talking about the woodgrain knob on a bodys? it's held on with a small allen set screw. then unscrew the whole knob and black center.
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers GarysMocars Legendary Dealer
[Re: 65cuda]
#68537
06/06/08 02:36 PM
06/06/08 02:36 PM
Posts: 74,976 U.S.S.A.
JohnRR
U.S.S.A.
no sounds like a pistol grip handle .
put in the feeler blade and give the handle a good hard yank
Re: Remove '70 4spd slip-fit shifter handle.
[Re: Dougo3]
#68541
06/06/08 03:57 PM
06/06/08 03:57 PM
Posts: 4,084 Indiana
W5Duster436
Indiana
I've had trouble with the feeler gage bending. I use a hack saw blade...just dont saw your fingers off
You have to do both sides right? It's been years since I did this and yes my blades were bending too. I don't think there is any way that two hacksaw blades will fit as on .010 and one .008 won't hardly fit.
[Re: Dart 340]
#68544
06/06/08 07:32 PM
06/06/08 07:32 PM
W5Duster436
Indiana
Should be only on the drivers side. If you have trouble let me know and I can send you a picture of one out of a car.
the driver's side is the side that I can't get the feeler gauge to go down. Drats..
It is almost like it hits that area where the first little pin is on the outer casing.
I remember not having any issues doing the pistol grip in the cuda but this one is a bear. for some reason I thought both sides had to be done. Will try again this evening when it cools off.
