Re: 1970 RR 4-speed Hurst lever questions
[Re: coffeeman383]
#685337
05/01/10 12:33 PM
05/01/10 12:33 PM
Posts: 17,524 Las Vegas, NV
6bblgt
Las Vegas, NV
1. Were all D21 4-speeds pistol grips? YES 2. Is the build sheet J42 'Pistol Grip Trans Knob' ever marked? Mine is blank (1970Chargerregistry has them all blank as well). NO 3. Is this a 1969 part? NO A 3-speed part? NO Is the ball Mopar? ?? Could this be correct? possibly '64-'65 Pictured lever looks like an "over-the-counter" HURST lever, possibly came with a new shifter purchased aftermarket. It resembles the 4-speed '64-'65 b-body unit, but I'm not sure if it is factory.
[Re: coffeeman383]
#685338
05/01/10 05:25 PM
05/01/10 05:25 PM
Posts: 5,447 So Cal
Sinitro
So Cal
This is the stick and ball that was in my 70 RR E63/D21 383/4-speed when I bought it in 1982. The ball is plain white (now yellowed) no markings, no part numbers, screwed onto the stick. The stick is marked 4078 maybe 4079. Questions: 1. Were all D21 4-speeds pistol grips? 2. Is the build sheet J42 'Pistol Grip Trans Knob' ever marked? Mine is blank (1970Chargerregistry has them all blank as well). 3. Is this a 1969 part? A 3-speed part? Is the ball Mopar? Could this be correct?
The 4078 handle was the aftermarket handle used with their Competition Plus shifter. Also the 70 RR used the Pistol grip which had a slide-in fitting rather than the (2) bolts...
Just my $0.01..
[Re: coffeeman383]
#685341
05/02/10 03:14 PM
05/02/10 03:14 PM
Posts: 267 Santa Clara , ca
ramcuda
Santa Clara , ca
Can I Hijack here ..
Im in need of info in the same area to..
I'm building the sbird and i have been trying to put something together that will work and yes i know the PG and box needs to be a stab in..
Here what i got
I have a GP for a console but it has the two bolt holes in it ( what app is it for )
Now the box i have is what i can find goes to 70-71 e-body BUT it looks to be a stab in handle ..is that right ? Thought by that point they where all bolt in handle..
I have a set of shifting rods from a 69 charger .. I know i will have to drill out the tabs to fit the rod .. we are not useing the lock out thing ...
We do not have a console in the car right now .. So do you think if i fit this all together will it work ? and will it shift with out the PG hitting the dash ?
1965 Ply "RAMCUDA" got to see it!!!<--- Should sell it/ 1970 Superbird <------ Just one big argument/ 1980 Jeep CJ5 <--- Just wheel it/ 2000 Dakota R/T <--- Should Drive it more/ 2001 Dodge Caravan <----- Cant kill it/ 2004 Dodge 2500 4dr DIZLE 4x4 <---- LOVE IT !!! www.moparalley.org
[Re: coffeeman383]
#685342
05/02/10 07:03 PM
05/02/10 07:03 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
Great call guys. I'm so used to seeing the two hole style it never dawned on me anything else existed. Went out and scrubbed the shifter and took a poor picture...Hurst Competition Plus! Now I'm left to wonder why....everything else on the car was stock, even the 14" road wheels and AM radio. Thanks!
Changing the sloppy stock Hurst shifter mmechanisme was standard operating procedure for anyone who wanted to have a faster shift. The pistol grip was not as bad as the shifter in the 69's. I used to hit my knuckles on the dash evrytime I hit 3rd! I switched mine to a Competition Plus because it has a positive stop (adjustable bolt) for the throw of the shifts. You can take a stock pistol grip and drill it to bolt into the Competition Plus shifter. That way you maintain the stock appearance with an upgraded shifter mechanism. I would definitely keep the shifter and change the handle.
[Re: RoadRunnerJD]
#685343
05/02/10 11:23 PM
05/02/10 11:23 PM
Posts: 5,447 So Cal
Sinitro
So Cal
If the shifter gate is fine, and you want the original look.. Pick up a later Hurst repro handle/pistol grip lever they are about $200 for the non-console version, and does have the (2) bolt holes..
Just my $0.01..
