hardened drill bit, which one?
#685242
05/01/10 10:33 AM
05/01/10 10:33 AM
RapidRobert
What kind of bit should I find to drill into some hardened steel. I tried a carbide (iirc) bit and it wouldn't touch it. Thank you for your time.
Re: hardened drill bit, which one?
[Re: Scott Carl]
#685244
05/01/10 03:04 PM
05/01/10 03:04 PM
RapidRobert
Scott what I am trying to do is drill into each end (horizontally) of the dist adv plate so I can put in 2 setscrews so I can adj the mech adv by rotating the dist around so I can access/remove the vac can to get to them/adj both/reinstall the can and turn the dist back to close to it's orig position & retime it. "the tool house" sold me I think it was a carbide bit and it made a slight depression and that was it. Not for sure if I can get up there in the near future, I have plenty of time but I am beyond broke . Any ideas w what I shared on what I need for a bit? I have those AVS rods/jets out if we can get connected & work something out. Are you jonseing to get it back together? Later. RR
[Re: RapidRobert]
#685246
05/01/10 04:54 PM
05/01/10 04:54 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
Are you using a drill press or hand drill? What size hole? How fast are you running the bit? If you are trying to drill and got a dimple with a regular bit first, the steel,(even mild steel) may have become "work hardened" which would make further drilling even harder, even with a carbide bit. Only thing I can suggest if that is the case is to start with a new carbide bit and best to do it in a drill press and maintain even but firm pressure. Unfortunately, if the steel has become too hard, you may need to try another plate. Hope that make sense or helps. I tend to agree with Stanton, though. It doesn't seem that that piece should be that hard but I could be wrong. No hurry on the carb. Got daughter's wedding coming up next month so as you can imagine, I'm broke for a while. Still wouldn't mind talking "shop" if your in the area and have time for coffee or even something "cold"
[Re: RapidRobert]
#685247
05/01/10 05:01 PM
05/01/10 05:01 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Such parts are usually case hardened; the case might only be a few thousandths thick, if you can get through the case the rest will drill easier.
I usually use a carbide rotary burr to cut through the case.
