from previous posts the arruzza mounts fit closer to stock. they send a tiny bit more vibrations into the car, not that much, because of the solid mount on the left side.
i used shumacher mounts on my car, 72 road runner auto, and they worked. they mount the motor a bit, less than 1/2" to the passengers side, and about 1/2" higher than stock.
i have a 572 hemi, stage 5 heads indy single plane intake, and have a working air grabber hood. i had to modify the intake and the air cleaner but the air grabber hood works perfect.
one thing to keep in mind. it seems like no hemi bolts in without modifying making something to make it fit. even if you are using stock hemi stuff, repo hemi parts or conversion parts. you probably will have to finesse something to get everything to fit like you want it to.
