What's Up With This BB Motor Mount Bracket? #684970
04/30/10 08:51 PM
04/30/10 08:51 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
This looks like any other basic BB B/C/E body motor mount bracket, except for the extra hole.
Is this for some kind of special application, or did somebody with a drill make a custom mount?
Re: What's Up With This BB Motor Mount Bracket? [Re: vdriver] #684971
04/30/10 10:32 PM
04/30/10 10:32 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
That really looks like that super secret MM from the skunkworks down near Area 51. On the other hand it looks like someone drilled it, that would be the right side mount and there doesn't appear to be anything there that would require that hole.
Re: What's Up With This BB Motor Mount Bracket? [Re: vdriver] #684972
05/01/10 08:26 AM
05/01/10 08:26 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I've seen chain used on horsepower monsters to keep the motor from ripping out of it's mount...
Re: What's Up With This BB Motor Mount Bracket? [Re: Commando1] #684973
05/01/10 09:29 AM
05/01/10 09:29 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
was that hole drilled or was it punched out like the rest of the holes?
Re: What's Up With This BB Motor Mount Bracket? [Re: MO_PA] #684974
05/01/10 10:03 AM
05/01/10 10:03 AM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
Does it matter...??? It not factory
Re: What's Up With This BB Motor Mount Bracket? [Re: MO_PA] #684975
05/01/10 10:05 AM
05/01/10 10:05 AM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
Looks to be punched, and is smaller than the rest at .41"...the rest are .5".
Re: What's Up With This BB Motor Mount Bracket? [Re: vdriver] #684976
05/01/10 10:08 AM
05/01/10 10:08 AM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
maybe as guy did this one too..LOL
Re: What's Up With This BB Motor Mount Bracket? [Re: 340dart4spd ] #684977
05/01/10 10:15 AM
05/01/10 10:15 AM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
Check out the *upper* set in this pic I found in the for sale section. It has the same hole, and they're listed as BB A body..?
Re: What's Up With This BB Motor Mount Bracket? [Re: vdriver] #684978
05/01/10 10:26 AM
05/01/10 10:26 AM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
Pretty sure pass side are the same ..driver side is the funky one on an A body
Re: What's Up With This BB Motor Mount Bracket? [Re: vdriver] #684979
05/01/10 10:34 AM
05/01/10 10:34 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I will have to check my collection of A-Body big block mounts.
JB Rhinehart, Realist
A-Body's RULE!
Re: What's Up With This BB Motor Mount Bracket? [Re: Rhinodart] #684980
05/01/10 12:56 PM
05/01/10 12:56 PM
PA
U
unclemike Offline
unclemike  Offline
U
PA
The upper right in the picture is the driver's side motor mount. It bolts on to the two holes in the oil pump flange and the front ear on the side of the block. Some B-RB blocks have the bosses but not drilled and tapped and some don't even have the bosses. Some C-body cars used the same set up and that's how I got a 440 for a good 361 and a $125 back in the day.
