Re: I have ignition related troubles please HELP
[Re: SPWC]
#684832
04/30/10 06:11 PM
04/30/10 06:11 PM
RapidRobert
I'd take off the starter solenoid wire to termporarily disable the starter (to keep from running the batt down and for the noise distraction) and have a helper hold the key to "start" while you check voltages to the ballast, to the ecu, to the coil positive primary terminal all of which need fire. Start at the bulkhead and work downstream or if your good there go back toward the ign sw. www.mymopar.com should (dont know if they have truck apps) have the colors to help you. (temporarily) disabling the starter will skew your readings as it is not now a normal cranking voltage reading(s) but you have an outright "open" somewhere that'll be apparent when you test that particular connection. Is this an OE 4 terminal ballast/5 pin ECU? If so 2 pins on the 5 pin ECU need fire. Grab your VOM
[Re: Cudajon]
#684836
04/30/10 11:08 PM
04/30/10 11:08 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
intermittant pickup failure is very common also. I have diaged this in the past, but having a spare electronic distributor handy. When it quits. Verify you have no spark, by pyulling the coil wire and obsrving for spark whle turning the engine over. If no spark is present, plug in the spare distributor (at the 2 pin magnetic pickup lead) and spin it by hand while looking for spark at the disconnected coil wire. If you suddenly have spark, you found the problem.
[Re: dave571]
#684837
05/01/10 02:43 AM
05/01/10 02:43 AM
Posts: 5,163 CT
GTX MATT
CT
My car did this once and I thought it was the connection at the bulkhead. Turns out when I let go of the key at the gas station it just didnt snap back to the right spot. Headlights worked, interior lights work, hazards work, anything that works with the key off works.
