Where to get Replacement Wire Terminals? #684798
04/30/10 03:59 PM
04/30/10 03:59 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
Anyone know a good source of factory style electrical harness connectors?
Specifically it's for a 64 Dodge - need male / female plastic terminal connectors for fron parking lamp connections.
I see a lot of universal stuff out there but it's not the same.
Thanks!
Re: Where to get Replacement Wire Terminals? [Re: HitIt] #684799
04/30/10 06:22 PM
04/30/10 06:22 PM
IN
ahy Offline
ahy  Offline
IN
M & H Wiring makes the repop harnesses with OE style connectors for MOPARs. They may sell the connectors by themselves. They normally sell through Year One but I'm sure they would at least take an inqiry directly.
FWIW I used M&H harnesses on a '70 Challenger and used a universal type two prong connector to repair the pigtail on my side marker light. It plugged right into the factory style harness. Yes its different but it doesn't show much.
Re: Where to get Replacement Wire Terminals? [Re: ahy] #684800
04/30/10 06:41 PM
04/30/10 06:41 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Some of the plastic connector bodies are available from multiple sources (probably one manufacturer), but some of the restoration suppliers may have them. I'll check to see if I can find anything.
Re: Where to get Replacement Wire Terminals? [Re: Jim_Lusk] #684801
04/30/10 06:43 PM
04/30/10 06:43 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
Great, thanks guys. I'll check out M & H Wiring.
If you do find any info it will be appreciated.
Re: Where to get Replacement Wire Terminals? [Re: HitIt] #684802
04/30/10 06:48 PM
04/30/10 06:48 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
Nope, nothing from M H. NO way to get the terminals from Year one either. I'll probably just switch over to a universal setup.
Re: Where to get Replacement Wire Terminals? [Re: HitIt] #684803
04/30/10 07:18 PM
04/30/10 07:18 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Not quite sure exactly what type of connector you're looking for but I went to the local pick and pull and scroundged around Dodge vans and Old Jeep Grand Cherokees (70's) for the running lamp connectors on my 69 RR. I came home with several sets. these are the two prong, 1 bare end with one end isolated in the rubber connector.
Re: Where to get Replacement Wire Terminals? [Re: NV69B7RR] #684804
04/30/10 07:57 PM
04/30/10 07:57 PM
Andrewh Offline
Andrewh  Offline
you can get some pretty good connectors from del city.
Get the waterproof gm style.
