Master cylinder/bosster upgrade #684760
04/30/10 02:51 PM
04/30/10 02:51 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Hi Guys !
STill having the same problem in my 67 Barracuda.
Power brakes just suck !! Very poor vacuum,But I've seen an alternative with parts from an early model I could fit in my car, can someone help me on this ?
Dan
Re: Master cylinder/bosster upgrade [Re: Wedgeman] #684761
04/30/10 03:12 PM
04/30/10 03:12 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
If you have poor vacuum then changing to another vacuum booster will not help.
You could try a
  • add a vacuum reservoir
  • add a electric vacuum motor
  • or change to a Hydro boost.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
