Re: "Don't ask me how I know..."
#674
07/11/03 10:18 PM
07/11/03 10:18 PM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
Mopar Jamie is the crowning king of "Don't ask me how I know..." If it can happen it will to him. I feel for ya Jamie.
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
[Re: bill_greenwood]
#677
07/11/03 10:39 PM
07/11/03 10:39 PM
A stock oil pump shaft should not be used in conjunction with a HV oil pump for very long... Welded spider gears in a 7 1/4 will NOT last very long on the street... It will not only take me a couple of years to finish my car...
[Re: amxautox]
#678
07/11/03 10:47 PM
07/11/03 10:47 PM
. . .but, an 833 4-spd trans can go into reverse and 1st at the same time. Then when you let out the clutch your car is fighting with the trans to go in both directions at once.
[Re: MOPAULY]
#684
07/12/03 12:46 AM
07/12/03 12:46 AM
Posts: 2,381 corpus christi,texas
dwdart
1. Craftsmen chrome sockets should NOT be used in conjunction with a ratchet, a 3 foot breaker bar, and all your body weight to loosen frozen camber bolts.... 2. Improperly placed creepers make interesting skate boards (see comment #1) ROTFLMAO i can see this. don't ask me how i know.
[Re: Michael Ecks]
#688
07/12/03 01:24 AM
07/12/03 01:24 AM
Don't touch the nice exhaust tips that stick out the back of the car while you're breaking in the camshaft at 2500 rpm just to see if they get hot.. Don't attempt to check the electric fan on a friend's camaro while the engine is running...
the entrance of a cooler liquid(water) into a overheated radiator/engine of an DemoDerby vehicle usually administers a scalding shower to the unsuspecting person(s)and emits an loud audible knock from within the bowels of the heated beast...
If your trying to impress your girlfriend, make sure that your stronger than the 8 3/4 chunk that your trying to install by yourself...
lastly,when installing the toyota 5spd trans in by yourself because it's nothing compared to an 833,make sure you don't fill it up with lube first,get stuck with it on your chest under the car and accidentally kick and thrash the plug that you had on the end of the trans or you may end up with 90 weight underwear and jeans...
[Re: 440Wedge]
#689
07/12/03 01:28 AM
07/12/03 01:28 AM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
Oh ya, Dont jack up your car by the K-member. Floorjacks have a tendancy to slide, therefore falling off and making the top of the radiator curved while the bottom has a nice pinch. Suprisingly, said radiator held water, it only jarred a hose loose.
Dont try to R&R a trans in the gravel. Its not fun, your car has to be extrememly high on stands at 4 corners and use Monster Garage Mantra: "When hands fail, Let feet flail"
Dont use a trans if pan is filled with shavings. Dont assume shavings and black fluid are from lack of service for 29 years. You would be better off using original trans with a weak low/reverse band.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
#690
07/12/03 07:46 AM
07/12/03 07:46 AM
[quote} never "feel" your brake rotor for scratches through the holes in your wheel with your finger right after going down a steep hill in stop and go traffic.
Wish you told me this before!!
......but always have cat litter availble when changing the oil, the old filter gasket can get stuck and not come off preventing a good seal for the new filter and therefore allowing five quarts of oil to spread across the garage floor.
LMAO Last night and now this morning....priceless stuff!
[Re: BSharp]
#692
07/12/03 09:01 AM
07/12/03 09:01 AM
The lower drawer of your tool box does NOT make a good jack stand if your car is too close to your box. Courtesy of a bone headed co-worker 2 days ago!
