Re: cutting open an oil filter
[Re: 69 Road Chicken]
#68349
06/06/08 12:55 AM
06/06/08 12:55 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
the nasty stuuf from the engine will be on the inside of the element, not on the outside...
I am truckless..
#68350
06/06/08 01:07 AM
06/06/08 01:07 AM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Summit Racing sells a filter cutter. Simply attach the filter, turn the crank handle & it cuts it in half. About $35. A friend who turned wrenches on a top fuel team, said they would cut the filter open & put a torch to it. Any metal particles would burn differently, depending on their what kind of metal it was. Aluminum would burn differently than steel, etc. That way, they could identify pretty much what part of the motor it came from. Don't think we have to go that far, but it will tell you if metal is in the oil.
[Re: John_Kunkel]
#68355
06/06/08 08:08 PM
06/06/08 08:08 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
Here's my home made filter cutter patterned after the commercial aircraft unit. Cutter wheel is from a common pipe cutter.
NICE work John! Does the filter fitting portion allow the filter to spin?
Nice...you take filter inspection seriously!
#68358
06/06/08 11:10 PM
06/06/08 11:10 PM
Posts: 8,144 Arkansas
340727dart
Arkansas
Here's one for $40. Oli filter Cutter
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
