Hey there, I just got done breaking in my new 360 and drove it a good 20 miles today. No leaks or anything. Heres my question, my cold oil pressure is about 50psi idle and 60psi reving. When I got back from my test drive it was good and hot and it had 20-25psi @ idle and cruising at 2500rpm I had 40psi hot. Does this sound right? Im running rotella 15w-40.
Im going to do an oil change on it this weekend, should I run the same oil? And should I cut open the oil filter and see if there is any shavings or particles?
