New 360 broke in questions #683437
04/29/10 12:40 AM
04/29/10 12:40 AM
Colorado
swingers_rock Offline OP
super gas
super gas
Colorado
Hey there, I just got done breaking in my new 360 and drove it a good 20 miles today. No leaks or anything. Heres my question, my cold oil pressure is about 50psi idle and 60psi reving. When I got back from my test drive it was good and hot and it had 20-25psi @ idle and cruising at 2500rpm I had 40psi hot. Does this sound right? Im running rotella 15w-40.
Im going to do an oil change on it this weekend, should I run the same oil? And should I cut open the oil filter and see if there is any shavings or particles?
Re: New 360 broke in questions [Re: swingers_rock] #683438
04/29/10 12:44 AM
04/29/10 12:44 AM
Hi Ori, your pressures are perfect
Re: New 360 broke in questions [Re: RapidRobert] #683439
04/29/10 12:51 AM
04/29/10 12:51 AM
Colorado
super gas
super gas
Colorado
Hey Robert its been awhile!
Good to hear, I was kind of worried of the pressures being "low" when hot. But good to hear that they are good.
Re: New 360 broke in questions [Re: swingers_rock] #683440
04/29/10 12:58 AM
04/29/10 12:58 AM
Yes it has been awhile. I gotta hit the hay as I am going to help a buddy tomorrow @ 8AM . I'll get back to you.
