what are my options for low profile large capacity oil #682696
04/28/10 04:54 PM
04/28/10 04:54 PM
So Cal
HealthServices Offline OP
Why would you even post that?
So Cal
I'm tired of my deep pan catching on everything. What are my options for low profile large capacity oil pans?
440 on a 1969 Road Runner
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: what are my options for low profile large capacity oil [Re: HealthServices] #682697
04/28/10 05:12 PM
04/28/10 05:12 PM
Long Island, NY.
Stroked65Belv Offline
Long Island, NY.
I would have to say not very many! I too have done an exhausting search into this after I changed my K frame to a tubular version and noticed all the room available to me now. With all the manufacturers out there the only type available with a hi-capacity and low profile was only with the rack and pinion steering option which was $$$$$$$$$. so back to the 7" deep pan and drag link set up.
If you find something let me know!
Re: what are my options for low profile large capacity oil [Re: Stroked65Belv] #682698
04/28/10 05:24 PM
04/28/10 05:24 PM
So Cal
So Cal
'course I had to take a picture and I realize that if I change the pan. The new low point will be the headers!
Re: what are my options for low profile large capacity oil [Re: HealthServices] #682699
04/28/10 06:06 PM
04/28/10 06:06 PM
Sparks,Nv.
P
pete Offline
super street
pete  Offline
super street
P
Sparks,Nv.
Sorry don't have a pic but I had mine made by charlie's. Gave him dimensions and drawing and he made the pan. Pete
Re: what are my options for low profile large capacity oil [Re: pete] #682700
04/28/10 06:48 PM
04/28/10 06:48 PM
IN
ahy Offline
ahy  Offline
IN
The "hemi" pan is a cost effective option... about one inch deeper than stock. In theory +2 quarts for 6 quarts in the pan but it works better with 5 in the pan. The Milodon circle track pan is an (expensive) option then there's a custom pan from Charlies with kickouts... kinda like the circle track pan.
With the Hemi pan in a very aggressive application, a pressurized oil reserve tank may be a good choice to make sure there's always oil.
Re: what are my options for low profile large capacity oil [Re: ahy] #682701
04/28/10 08:37 PM
04/28/10 08:37 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Milodon 31580
costs 450-500 including pickup
worth every penny
I want my fair share
Re: what are my options for low profile large capacity oil [Re: SomeCarGuy] #682702
04/28/10 09:04 PM
04/28/10 09:04 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What would you rather tear a hole in, the pan or a header ?!?!?!
1) raise the car up - personally I like the high 60's/'70's superstock look
2) build a skid plate on the k-frame - doesn't have to go completely under the pan but enough to kit before the pan does
Re: what are my options for low profile large capacity oil [Re: Stanton] #682703
04/28/10 09:48 PM
04/28/10 09:48 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The Milodon low-profile 8-quart pan is on my Roadrunner, also used one on a Duster.
I've never whacked an oil pan on anything except one time on the race car after a bumper-dragging wheelstand, and that car has a huge SS-style pan. I've never whacked headers on anything either, but none of my cars are as low as yours is; generally I run 1" minimum clearance to the bump stops.
Re: what are my options for low profile large capacity oil [Re: Stanton] #682704
04/28/10 09:53 PM
04/28/10 09:53 PM
So Cal
So Cal
Nope not going super stock racing not anymore.
most likely will at least do a temporary skid plate though
Re: what are my options for low profile large capacity oil [Re: HealthServices] #682705
04/28/10 09:58 PM
04/28/10 09:58 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I made a skid plate for the Torana since the new pan stuck down a little...
(No where near as much as your's though )
Re: what are my options for low profile large capacity oil [Re: HealthServices] #682706
04/28/10 09:59 PM
04/28/10 09:59 PM
AndyF Offline
AndyF  Offline
Milodon circle track pan is about the only thing off the shelf that will fit.
Re: what are my options for low profile large capacity oil [Re: HealthServices] #682707
04/28/10 10:00 PM
04/28/10 10:00 PM
SomeCarGuy Offline
SomeCarGuy  Offline
Maybe one day i will get around to taking a pic of my car. I don't think a skid plate would really do much given the way the pan sits.
With all the baffles and even the port for a temp sender, the circle track pan is really a pretty trick piece for not THAT much more than other pans.
I just went and looked out of curiosoty and you can still get them for 450 plus shipping. So about 460 at Summit.
Re: what are my options for low profile large capacity oil [Re: SomeCarGuy] #682708
04/28/10 10:20 PM
04/28/10 10:20 PM
So Cal
So Cal
I think I will have to do something like that, but at the same time get a something like the TTI headers or some other header that does not go under the centerlink. So this is starting to sound like a 1500 dollar fix.
