can I use a stock choke pull-off? #682544
04/28/10 10:13 AM
04/28/10 10:13 AM
Just South of The Motor City
limechallenger Offline OP
I've got a 360 with a Edlebrock Performer intake and a holley 750 in my 78 Aspen R/T . The intake has the choke valley(for lack of a better name),but I need to know what choke pull-off will work for this combo? Any ideas?
70 T/A Challenger 78 Aspen R/T 87 Indy 500 Dakota
Re: can I use a stock choke pull-off? [Re: limechallenger] #682545
04/28/10 12:32 PM
04/28/10 12:32 PM
Re: can I use a stock choke pull-off? [Re: limechallenger] #682546
04/28/10 02:24 PM
04/28/10 02:24 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I guess it depends on what 750 Holley you have. More than likely you'll have to run a manual choke unless you have good fabrication skills.
Re: can I use a stock choke pull-off? [Re: limechallenger] #682547
04/28/10 06:54 PM
04/28/10 06:54 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You're talking about the choke itself, no? I believe electric chokes are available on hollies, ain't they? And there's gotta be a pulloff that will work on them too.
Re: can I use a stock choke pull-off? [Re: limechallenger] #682548
04/29/10 10:09 PM
04/29/10 10:09 PM
Virginia
JimG Offline
JimG  Offline
Virginia
FWIW, I think you'll need to find an OEM Holley and grab the entire choke mechanism, pulloff and all, and move it to your aftermarket Holley to make the pull off work.
It's something I've long considered and never tried. Maybe someday.
