Fuel Filter Location(s) on 440-6 motors? #68241
06/05/08 09:04 PM
06/05/08 09:04 PM
Anonymous OP
Anonymous OP
Hello,
Was just looking at (I think) a stock 440-6 motor and was wondering where the fuel filter is?
I know there is the sock in the fuel sending unit pickup in the tank. Is the external fuel filter inside that Vapor Separator unit near the fuel pump? If so, how can you easily (or cheaply) change the fuel filter? Do folks add another in-line unit near the carb generally?
Thanks for your input.
Re: Fuel Filter Location(s) on 440-6 motors? #68242
06/05/08 10:06 PM
06/05/08 10:06 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
On a stock 440-6 pk, the only filter is in the vapor separator. I have seen guys run an extra filter after the vapor separator.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Fuel Filter Location(s) on 440-6 motors? [Re: 70sixpkrt] #68243
06/05/08 10:23 PM
06/05/08 10:23 PM
Anonymous OP
Anonymous OP
It's been about a thousand years since I had my 6 pack, but aren't there the little cartridges in the carb inlets?
Re: Fuel Filter Location(s) on 440-6 motors? #68244
06/05/08 10:29 PM
06/05/08 10:29 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
Each carb has a sintered brass filter, spring loaded, at the fuel inlet. Still sold today.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: Fuel Filter Location(s) on 440-6 motors? [Re: Kowal] #68245
06/05/08 11:11 PM
06/05/08 11:11 PM
70sixpkrt Offline
70sixpkrt  Offline
I learn something new everyday.
4-speed
3:54 Dana
Re: Fuel Filter Location(s) on 440-6 motors? [Re: Kowal] #68246
06/05/08 11:18 PM
06/05/08 11:18 PM
Anonymous OP
Anonymous OP
How often should these filters be changed? Same as regular fuel filters?
Does anyone have link to see or buy this filter? And about what do they generally run cost-wise?
Thanks a lot!
Re: Fuel Filter Location(s) on 440-6 motors? #68247
06/06/08 04:40 PM
06/06/08 04:40 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
don't forget the filter on the tank sending unit
