Kickdown linkage 727 #682468
04/28/10 03:41 AM
04/28/10 03:41 AM
Germany
JS23U Offline OP
JS23U  Offline OP
Germany
Hi,
I need a picture and measurements of the "throttle lever" at the 727 trans of a 3 piece linkage setup. The number of the lever is 2536270, per Master Parts Catalog it is correct for all 727 at least in 1970, probably earlier years too.
This is the lever down at the trans that bolts to the small vertical shaft.
A good pic would help a lot. Also very important, how much is the distance between the mounting hole and the other hole?
Jens
Re: Kickdown linkage 727 [Re: JS23U] #682469
04/28/10 03:48 AM
04/28/10 03:48 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
More info would help... Small block or big block? 2 Barrel or 4 Barrel? Maybe SIX BARREL? Maybe you didn't know that even the slant six was available with a 727 trans.
Re: Kickdown linkage 727 [Re: Kern Dog] #682470
04/28/10 04:01 AM
04/28/10 04:01 AM
Germany
JS23U Offline OP
JS23U  Offline OP
Germany
I need it for a 1970 Challenger with 440.
From what I read the lever is used on all engines 340 and up. Possibly not on the 318 and Slant 6 but I don't know.
Jens
