Stock Springs with the Summit 224/234 cam? #682432
04/28/10 01:51 AM
04/28/10 01:51 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Would stock HP springs be okay with the summit 224/234 cam? If not what springs would be ok? I have a set of HP springs. If I have to buy springs I think I may just go with the XE268 from Comp.
Re: Stock Springs with the Summit 224/234 cam? [Re: GTX MATT] #682433
04/28/10 01:04 PM
04/28/10 01:04 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
If the specs on your springs match the requirements for that cam you'll be fine.
Re: Stock Springs with the Summit 224/234 cam? [Re: bobby66] #682434
04/28/10 03:32 PM
04/28/10 03:32 PM
Stock HP would be around 90 seat 250 open and that would be fine--Comp 911 is a good one for that cam if you are going to raw hide it once in a while --they will not work with stock retainers very well as the diameter is slightly bigger---for just a cruiser go for it the lower pressure may give the cam and lifters a fighting chance--I like the Morel, brand of lifter and the latest sealed power brand are also way better than the Summit brand of lifter That is one GREAT street cam you will love it
Re: Stock Springs with the Summit 224/234 cam? [Re: ] #682435
04/28/10 04:09 PM
04/28/10 04:09 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
GEEZ - get a set of springs and do it right or do you feel lucky? Some can get by .
This is what happened with a 474 lift cam with stock springs on a 360. Granted it had short springs with rotators (a lot of 360's have them). Coil bind is not cheap. Plus your stock springs have how many miles on them????? Pictured is only partially showing the damage. A set of springswill be well under a hundred bucks so -------------
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Stock Springs with the Summit 224/234 cam? [Re: MoparforLife] #682436
04/28/10 04:41 PM
04/28/10 04:41 PM
scratchnfotraction Offline
Don,sure have used that pic a lot latly Huh?
some just dont get the new matched spring deal,well worth the $ and performance..
even I am not that cheap
that pic shows the cost of used stock springs with out a doubt
sorta like the 1.88 vs 2.02 valves or the LD340 vs airgap rpm
Re: Stock Springs with the Summit 224/234 cam? [Re: GTX MATT] #682437
04/28/10 05:25 PM
04/28/10 05:25 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Stock Springs with the Summit 224/234 cam? [Re: MoparforLife] #682438
04/28/10 07:38 PM
04/28/10 07:38 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
This is actually why I was asking, I was planning to run it with stock HP springs but was following that thread and figured Id get some feedback.
Any springs that I could go with without having to change the retainers? This cam wont be in the engine too long.
Re: Stock Springs with the Summit 224/234 cam? [Re: GTX MATT] #682439
04/28/10 08:03 PM
04/28/10 08:03 PM
Upper Midwest
Upper Midwest
A lot of the single springs with dampers use the OEM retainer and keepers.
