I decided not to use a hydraulic throwout bearing not only because they are expensive but since any leak or failure requires pulling the transmission.
So now I have a clutch fork sticking out the side of my Lakewood bellhousing. I still plan to use a hydraulic linkage to eliminate the Z-bar issues.
There is not a lot of room with the Hedman B-body headers for a push-type slave cylinder (and it would be above and close to one tube entering the collector). Would heat be a problem because of this? I could use a "pull" cylinder and mount it somewhere on the 833. Any
![](/ubbthreads/images/graemlins/Twocents.gif)
thanks.
