Re: Has anyone put a Ram v-10 in a street rod yet?
[Re: ramman16248]
#682156
04/27/10 11:07 PM
04/27/10 11:07 PM
Posts: 1,757 levittown pa
fstfish66
levittown pa
lot of motor there,,do a search maybe on allpar.com compare the weight of that iron V 10 to a small black and big block,, i have seen viper aluminum v 10s in street rods,,but never an iron from a truck,,still would be a kool project,,and since you have the motor,,,,,,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: fstfish66]
#682157
04/29/10 09:31 PM
04/29/10 09:31 PM
Posts: 10,562 Freeport IL USA
poorboy
Freeport IL USA
Biggest concern I see would be the length of the V10, front to back. Things tend to get a bit crowded between the rad and the firewall with a V8, I suspect the extra length would have to be accomadated by recessing the firewall into the passenger compartment, or by extending the front of the frame. Both would be do-able, but the firewall move would probably look better in a late 40s ride. Pre 35 you could get away with extending the frame and going fenderless, but the post 35's just don't look right fenderless IMHO. If you do the post 35 and extend the frame, you will need to deal with making the fenders look right. Of course, you can always do the rat rod thing, they don't seem to mind if things are out of porportion. Just for the record, 48 & newer trucks have a real short engine compartment, and recessing the firewall really eats up floor space in truck cabs. After all that, if the V10 was sitting in my shop, I could probably figure out a way to use it. Go for it, post lots of pictures, we ate all waiting to see the results. Gene
[Re: poorboy]
#682158
04/30/10 09:42 PM
04/30/10 09:42 PM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
I had a '37 Chrysler Imperial with a straight eight in it, lots of room there. (length wise anyway). Width wise, you might have to bump out the hood sides, but I'd still be bad a$$.
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
[Re: 79powerwagon]
#682161
05/03/10 07:54 PM
05/03/10 07:54 PM
poorboy
Freeport IL USA
So, I have a 48 Plymouth coupe sitting here still housing the original flathead 6. The firewall is not flat on them, around the back of the 6 the firewall has an offset towards the passenger compartment that is about 3" deep and about 12" wide. From the non-off set firewall, to the front of the fan blades is 28", as i remember, the fans run real close to the rad. The inner fenders are 22" at the narrowest point, (they are wide at the top and get narrow about 1/2 way to the frame, front to back on both sides) and the steering column sits under the narrow part of the driver side inner fender. The inner fenders can be moved and the steering column can be changed with a steering box upgrade, but the length will require some serious adjustments. Gene
