Hello,
Anyone here using the Hybrid Fiberglass Solutions base for Hemi with Eddy carbs? I bought one and it appears that it will sit the filter too high.I have a repro fiberglass base for the Carter carbs and it is more of a dropped base type. If I modify the FHS and it doesn't work, I cannot return it. It looks like even if I cut the throats off, it will still be higher than the original type? Anyone use one of these succesfully with the Air Grabber?
Thanks,
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
