I am looking to modernize my cooling system. #681535
04/27/10 11:03 AM
04/27/10 11:03 AM
Minnesota
MTSI Offline OP
super street
MTSI  Offline OP
super street
Minnesota
I have a 1971 Charger with a 440 and a Tremec 5-speed. I want to go with an aluminum radiator and electric fans.
Does anyone have a recommendation on a supplier or manufacturer of these items?
Re: I am looking to modernize my cooling system. [Re: MTSI] #681536
04/27/10 11:47 AM
04/27/10 11:47 AM
there's been some informative (to say the least ) threads on this lately. Might see if you can retrieve them. IMNHO I'd go w a large new alum rad (maybe a dual pass) and a good ole fashioned MP thermal clutch fan spaced 3/4 into a well sealed shroud w a 180 stant/milodon stat w a 1/16" bleed hole and a edel or milodon WP
Re: I am looking to modernize my cooling system. [Re: RapidRobert] #681537
04/27/10 12:02 PM
04/27/10 12:02 PM
Minnesota
MTSI Offline OP
super street
MTSI  Offline OP
super street
Minnesota
Thank you.
GO BIG RED
Re: I am looking to modernize my cooling system. [Re: MTSI] #681538
04/27/10 12:03 PM
04/27/10 12:03 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Stock is best, Alum radiator maybe, but keep the rest stock like was said above.
7 blade clutch fan, you can thank us later.
Re: I am looking to modernize my cooling system. [Re: MTSI] #681539
04/27/10 12:05 PM
04/27/10 12:05 PM
Thank you. GO BIG RED
For sure and it's getting closer and w Suh getting picked that early people are really fired up for what's ahead
Re: I am looking to modernize my cooling system. [Re: RapidRobert] #681540
04/27/10 12:26 PM
04/27/10 12:26 PM
Andrewh Offline
Andrewh  Offline
eh,I don't agree with the stock thing at all.
I have lost 3 radiators due to stock setups.
The fan dropped into the rad, or moved into it.
I like electric fans, but it can be hard or expensive to find one that moves enough air.
None of the after market ones I tried did very well.
The oem types that have been listed always seem to be better.
Just depends on how much room you have.
I also use a dual pass cross flow rad from 4secondsflat.com
Since yours is a manual you don't need the trans cooler anyway.
