Hemi, Shaker, AFB's #681526
04/27/10 10:45 AM
04/27/10 10:45 AM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
Getting close to firing the Cuda' after 3 years. I am having a hard time making fuel lines that will fit under the shaker. Been trying to make them out of 3/8 tubing. I see a kit on E-Barf for $189!!! That seems way too expensive for my cheap a$$. The problem is getting a tight enough bend, close to the carb's body, to clear the base. What have you guys used? I don't care about originality, just function, safety, and so long as it doesn't look like a hack job. Thanks-
Re: Hemi, Shaker, AFB's [Re: Kirby] #681527
04/27/10 10:49 AM
04/27/10 10:49 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I'd be curious what the bends look like on that 189 set especially if they are stainless , the 3/8 fuel full body lines I have seen in stainless have kinked bends . You can't easily, at least i haven't been able to yet, do those tight bends by hand ????
Re: Hemi, Shaker, AFB's [Re: JohnRR] #681528
04/27/10 10:58 AM
04/27/10 10:58 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
you need to buy the special 90 degree fitting to clear the base plate at the rear.
logan426
Re: Hemi, Shaker, AFB's [Re: MLR426] #681529
04/27/10 02:55 PM
04/27/10 02:55 PM
Walla Walla, WA
Hemi_Jack Offline
Hemi_Jack  Offline
Walla Walla, WA
These are reproduction lines but I don't remember where I got them.
Re: Hemi, Shaker, AFB's [Re: MLR426] #681530
04/28/10 12:50 PM
04/28/10 12:50 PM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
logan426
Anyone know of a source for the 90 degree fitting? My home town parts store is coming up empty.
Re: Hemi, Shaker, AFB's [Re: Kirby] #681531
04/28/10 02:32 PM
04/28/10 02:32 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Re: Hemi, Shaker, AFB's [Re: Kirby] #681532
04/28/10 02:37 PM
04/28/10 02:37 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Re: Hemi, Shaker, AFB's [Re: Kirby] #681533
04/28/10 04:11 PM
04/28/10 04:11 PM
JohnRR Offline
JohnRR  Offline
logan426
I got them it from year one but I was at pepboys and saw one that was similar and it may have been for a 3/8 line fitting , if you can go without 100% stock look one of them on each carb would make doing this easier with 3/8 line
