Master Cylinder Rebuild
#681458
04/27/10 08:18 AM
04/27/10 08:18 AM
Posts: 163 Beautiful Downtown Bahama, NC
tact1
Looking for a recommendation for someone to rebuild my master cylinder from a '69 Bee so that it looks right and works right. It is the original master cylinder.
"Four out of three people have a problem with fractions"
Re: Master Cylinder Rebuild
[Re: tact1]
#681459
04/27/10 11:13 AM
04/27/10 11:13 AM
Posts: 426 Mid-Atlantic
Scatransit
Mid-Atlantic
BE&A makes a nice top...the guts are still available from Wagner-at last check. If there is light scoring in the bore, a wheel cylinder hone will clean it up. If it's too bad, or pitted, it would be a a good idea to have it bored and sleeved. White Post Restorations can do this. Hope this helps...
[oo]======[oo]
[Re: Mastershake340]
#681461
04/27/10 01:45 PM
04/27/10 01:45 PM
Scatransit
Mid-Atlantic
I have not done business with White Post, I was just aware that they performed that type of service & passed it along... Thanks for the info...
[oo]======[oo]
#681462
04/27/10 01:54 PM
04/27/10 01:54 PM
Posts: 10,030 Wisconsin
Aero426
Wisconsin
Brake and Equipment Warehouse in Minneapolis does really good work restoring Mopar master cylinders.
Do you have their contact information?
[Re: Scatransit]
#681463
04/27/10 01:55 PM
04/27/10 01:55 PM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
White Post has been around for a while and advertised extensively in the major car restoration type publications, but there have been reports of problems with some of their work, plus complaints about their attitude. Brake and Equipment has really stepped up to the plate to become experts in restoring Mopar master cylinders, I've had them do a number of parts for me over the years with no complaints, in fact I've got one up there that they are working on for me right now. http://www.brakeplace.com/
[Re: FY1TA]
#681465
04/27/10 09:39 PM
04/27/10 09:39 PM
Posts: 643 southern conn
1969gtx
southern conn
apple hydralics does a good job
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: A0M397X]
#681469
05/03/10 05:32 PM
05/03/10 05:32 PM
tact1
Looks like Brake and Equipment gets the nod. I put on some SSB disc brakes, and they came with a new master cylinder. When I closed the hood on my Super Bee, the master cylinder punched through the air box for the scoops, so while I am fixing that I might as well get my original master cylinder done. Got to go back to the original because it is the only one that will clear the airbox. Tried a MOPAR performance unit, and it is taller than the replacement from Stainless Steel Brake Corp. Thanks for the input
[Re: tact1]
#681470
05/03/10 07:10 PM
05/03/10 07:10 PM
Posts: 54 Houston, TX
Crunchy_Frog
Houston, TX
... I put on some SSB disc brakes, and they came with a new master cylinder. When I closed the hood on my Super Bee, the master cylinder punched through the air box for the scoops...
Thanks for the heads up. I was contemplating SSBs on my N96 equipped Bee too.
