Although I have had several Mopars in my lifetime, I have never had one long enough to experience an axle bearing failure.
My 70 Charger has had the Green bearing "Upgrade" several years ago, but I have only put 3000 miles or so since. I put in a rear disc brake kit offered from Dr Diff. Great kit. Since the install, I have put on about 1000 miles.
Lately while driving along, the left rear corner has a rotational squeak that goes away when I turn right or press the brakes. I suspect the bearing. I don't remember if his disc kit allowed the retention of the tapered Timken bearings or not. I already had the Non adjustable Greens in at the time. I have yet to read here about axle bearings squeaking. Has anyone else?
