speedo pinion?
#681305
04/26/10 09:54 PM
04/26/10 09:54 PM
Posts: 2,234 BFE
vancamp
super street
super street
BFE
am i right if you have 275/60/15 tires and 3.23 gears you would need a green 31 tooth speedo pinion gear correct?
VanCamp Dent Systems
Paintless Dent Repair/
Mopar Restification
Re: speedo pinion?
[Re: vancamp]
#681306
04/26/10 10:31 PM
04/26/10 10:31 PM
Posts: 3,905 Minnesota
3twos
Minnesota
How tall are the tires? You may need the 33 tooth
Al & Sheila
Re: speedo pinion?
[Re: vancamp]
#681308
04/27/10 12:19 AM
04/27/10 12:19 AM
RapidRobert
I'd make a mark on the tire next to the pavement then measure the rollout on the pavement which'd be ~8-9 ft or so (not sure on the rest of the formula) to get an accurate figure as you dont want to have to pull it again.
Re: speedo pinion?
[Re: Ronnman]
#681314
04/27/10 10:36 PM
04/27/10 10:36 PM
Posts: 2,234 BFE
vancamp
super street
super street
BFE
The 30 tooth gear would be closer. See below Ron
I used the chart on here and it comes up with a 2838391 which is a 31, what would the speedo difference be between the 31 and 30? reason iask i have a 26,27 a 31 is on the way but dont have a 30.
Mopar Restification
Re: speedo pinion?
[Re: vancamp]
#681316
04/28/10 06:47 PM
04/28/10 06:47 PM
Posts: 25,842 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The actual math says you need a 30.25 tooth pinion, 30 is the closest.
