Aluminum radiator repair #68129
06/05/08 05:13 PM
06/05/08 05:13 PM
CT - just outside Hartford
Crazy73 Offline OP
Crazy73  Offline OP
It never fails, I just can't start my weekend a day early.
I replaced the coolant-weeping original brass radiator in my Dart Sport with a cross-flow dual-core aluminum radiator. I warmed up the car with the radiator cap off, checked for leaks, and waited until the coolant started bubbling. I then added more coolant mix until it was 1.5" below the cap, and still bubbling, then checked for leaks. I then capped it for a few minutes and triple-checked for leaks - it was solid. I thought to myself "time for a test drive" and drove out of the neighborhood.
Well, 1/2 mile away, while going through the first traffic light I heard a little "thunk" sound and then saw steam billowing out from under the hood. Yep, some sort of debris took out 1/4" at the edge of one of the rows about 3" from the top, and coolant began gushing out.
What's the easiest way to repair the radiator myself? I certainly don't want to buy another one, and I'd rather not be without the car for another 2-3 weeks while a shop bends me over repairing what I've got. I haven't been able to enjoy this car during the spring or summer for the last 3 years.
Should I just get some needle-nosed pliers and crimp & twist the offending core? I can't see 14-16psi being enough to burst through that...
Pete
-1968 Barracuda 4spd 383-6pk
Re: Aluminum radiator repair [Re: Crazy73] #68130
06/05/08 08:19 PM
06/05/08 08:19 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I don't know if solder will stick to aluminum, but I've had great luck fixing brass/copper ones with a some solder, and a soldering torch.
Just dry it out good, and gove it a try.
Re: Aluminum radiator repair [Re: dave571] #68131
06/05/08 10:17 PM
06/05/08 10:17 PM
Crazy73 Offline OP
Crazy73  Offline OP
I know lead/tin solder won't stick to aluminum, which is why I was thinking of crimping the tube.
Is it worth hunting down some tin/zinc solder (is that what they call "lead free"?), or am I best served with my initial thought?
Pete
Re: Aluminum radiator repair [Re: Crazy73] #68132
06/06/08 05:45 AM
06/06/08 05:45 AM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
I had a 1/16 in hole in one row on an aluminum radiator and fixed it with JB Weld. It held for the 6 years I owned the car without a leak. JB Weld was originally designed to fix aluminum and its proven itself to me. It's worth a try, just pack it in and smear it around so it has something to bond to, cheap fix if it works for you.
Re: Aluminum radiator repair [Re: maximus] #68133
06/06/08 09:15 AM
06/06/08 09:15 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
We use a product similar to this http://durafix.com/
Re: Aluminum radiator repair [Re: maximus] #68134
06/06/08 10:18 AM
06/06/08 10:18 AM
right between milan dragway & ...
Flite_727 Offline
Flite_727  Offline
i used jb weld too & it was holding up fine 5 yrs. later when i disassembled the truck it was in. i plan on re using the same rad. in the ramcharger in my sig. pic. FWIW i used a shop vac & lotsa duct tape to apply a slight vacuum to the inside of the radiaitor while the jb weld was curing i did this so the jb weld was actually pulled into the holes, covering both the inside & outside, instead of just sitting on top.
'06 Magnum R/T Daily driver, 5.7 N.A.- [email]12.63@109[/email]
Re: Aluminum radiator repair [Re: Flite_727] #68135
06/06/08 02:00 PM
06/06/08 02:00 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
It's actually quite easy... Use aluminum alloy rod and a torch and you are good to go. I used this process to mount some aluminum angle brackets to my summit radiator and it worked like a charm. Check out this link for a quick fix..
http://www.muggyweld.com/1clip3.html
The alumalloy rod melts at around 400 degrees so a small propane torch is all you need. TBF
Re: Aluminum radiator repair [Re: tpabayflyer] #68136
06/08/08 04:48 PM
06/08/08 04:48 PM
Crazy73 Offline OP
Crazy73  Offline OP
Thanks for the tips!
Pete
