Re: Blasting body parts with crushed Glass?
[Re: 84Stepside]
#68113
06/05/08 08:15 PM
06/05/08 08:15 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I believe it is the pressure and the heat generated form that pressure that causes the problem no the media. Sand requires 70-90 lbs to do its job and that generates a lot of heat. I had my AAR blastered with the pastic media and it turned out awesome. I have actually sand blasted small areas (you could cover with a dollar) on my R/T with out damaging anything. Find someone who uses the plastic and pay the price, you'll be happier in the long run. These are the only two medias I have personal experiences with. I think a member here that goes by Challenger1 has a great deal of experience with blasting, naybe he can help.
Careful, your character's showing!
[Re: mopar346]
#68114
06/05/08 10:02 PM
06/05/08 10:02 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Don't use glass beads except for hard items like brackets, hood hinges, trunk hinges, etc, sheet steel reacts to glass bead regardless of air pressure, the metal will swell were struck with the bead abrasive,.....sand is prefered, but messy to remove from all the crevises,.....I'd recommend "black beauty" silicate abrasive, "medium grade", and blast any sheetmetal at a 45 degree angle, and do not concentrate the media on any one area too long, heat is one of your enemies, the constant blasting is equivalant to "Pick hammering" it will affect the area if you stay on it to long!.....the black beauty "rolls" out of the crevises when you blow down the car after, sand just lays there
[Re: DAYCLONA]
#68115
06/06/08 05:30 AM
06/06/08 05:30 AM
Posts: 6,301 colorado
a12superbee
colorado
Not to jack the thread, but has the dry ice blasting become more widely available? Has anybody gone that route?
I can't afford this.
mark
[Re: 84Stepside]
#68116
06/06/08 08:26 AM
06/06/08 08:26 AM
Challenger 1
Cincinnati, Ohio
Does Blasting body parts with crushed Glass damage them like sand or is it ok? anything info will help, thanks
I've never blasted body panels with glass beads. I think it would be too exspensive, glass beads are designed to be reused in a blast cabinet. The idea is to use the least amount of air pressure to keep them intact, crushed glass is less effective. IMO I would suggest urea plastic media for the outside body.Big $$ but is safe to prevent warpage. Black beauty, black lighting, black this and black that, is coal slage. It's made by different people under different names, it's works just like silcia sand with a whole lot less sicia in it which is better for your health. It is fine to use for bottem of the car and engine compartment. I'm sure the glass beads would take forever to remove paint and may still warp the panels. Hope this helps.
[Re: Challenger 1]
#68117
06/06/08 09:10 AM
06/06/08 09:10 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Crushed glass is way different than glass beads. Crushed glass is much more agressive than beads, its like sand. I used it in a cabinet before.
I'm not sure of the advantage over silica or slag products though. I'm guessing it doesn't last as long.
I had body parts blasted with silica sand. The problem lies with people cranking pressure to get the job done faster. More pressure = more heat = more warp.
I had a 71 cuda blasted and it came out fine.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
