Re: 904 tailshaft bushing
[Re: JonC]
#681087
04/26/10 08:07 PM
04/26/10 08:07 PM
Posts: 5,895 Florida
Locomotion
I wonder if the later "500" OD trans has the same bushing. Maybe a later year 904 application than your car would still be on their files? If the bushing is bad, it may be the cause or it may have been caused by the vibration elsewhere! U-joints worn driveshaft dinged/kinked pinion angle off trans mount worn lost balance weight off driveshaft or wheels ??? moparts does have some transmission people/businesses who should be able to supply one or advise more.
[Re: JonC]
#681088
04/26/10 08:45 PM
04/26/10 08:45 PM
Posts: 1,822 Colorado
denfireguy
Colorado
I continue to chase down vibrations in my 340 Cuda with a 904 tranny. I am at the point of replacing the tailshaft bushing but neither Napa or Carquest has a part number for it, only the 727. Anyone know where I can get one?
Transtar Industries carries them. Part number 12066. Transtar part numbers can be crossed (and in many cases are the same) to just about any transmission supplier. To my way of thinking, this should be part of the rebuild kits. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: JohnRR]
#681090
04/27/10 12:01 PM
04/27/10 12:01 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
Jon, I remember you talking about changing this a couple years ago, I found the tool I have to do it in the car if you need it.
I tried to PM you, but your box is full.
[Re: JonC]
#681091
04/28/10 08:18 PM
04/28/10 08:18 PM
JonC
Millinocket, Maine
I also tried your Email and have not heard from you. Are you still around??
