904 tailshaft bushing #681086
04/26/10 07:31 PM
04/26/10 07:31 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I continue to chase down vibrations in my 340 Cuda with a 904 tranny. I am at the point of replacing the tailshaft bushing but neither Napa or Carquest has a part number for it, only the 727. Anyone know where I can get one?
Re: 904 tailshaft bushing [Re: JonC] #681087
04/26/10 08:07 PM
04/26/10 08:07 PM
Locomotion Offline
Locomotion  Offline
I wonder if the later "500" OD trans has the same bushing.
Maybe a later year 904 application than your car would still be on their files?
If the bushing is bad, it may be the cause or it may have been caused by the vibration elsewhere!
U-joints worn
driveshaft dinged/kinked
pinion angle off
trans mount worn
lost balance weight off driveshaft or wheels
moparts does have some transmission people/businesses who should be able to supply one or advise more.
Re: 904 tailshaft bushing [Re: JonC] #681088
04/26/10 08:45 PM
04/26/10 08:45 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Transtar Industries carries them. Part number 12066.
Transtar part numbers can be crossed (and in many cases are the same) to just about any transmission supplier. To my way of thinking, this should be part of the rebuild kits.
Craig
Re: 904 tailshaft bushing [Re: JonC] #681089
04/27/10 10:58 AM
04/27/10 10:58 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Jon, I remember you talking about changing this a couple years ago, I found the tool I have to do it in the car if you need it.
Re: 904 tailshaft bushing [Re: JohnRR] #681090
04/27/10 12:01 PM
04/27/10 12:01 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I tried to PM you, but your box is full.
Re: 904 tailshaft bushing [Re: JonC] #681091
04/28/10 08:18 PM
04/28/10 08:18 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I also tried your Email and have not heard from you. Are you still around??
