Re: Big Block Water Pump Leak?
[Re: stan1970]
#68097
06/05/08 04:32 PM
06/05/08 04:32 PM
RapidRobert
Stan welcome aboard. There are no dumb questions only unasked ones. sounds like a weep hole which is on the underside of the impeller assy which comes out by itself(4 bolts) & the wp housing doesn't need to be touched.
[Re: SPWC]
#68100
06/05/08 06:17 PM
06/05/08 06:17 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
B/RB water pump very simple to change. Loosen alternator, remove belts, remove 4 fan bolts, remove 4 pump bolts, rap pump off housing, cleans housing surface, install new gasket and pump in reverse proceedure.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: SPWC]
#68102
06/05/08 06:42 PM
06/05/08 06:42 PM
Drain it 1st. Replace with fresh coolant.
[Re: SPWC]
#68104
06/05/08 06:55 PM
06/05/08 06:55 PM
MoparforLife
Upper Midwest
What about draining the coolant,isnt that necessary?
hell it will self drain if you don't.
[Re: stan1970]
#68107
06/05/08 08:27 PM
06/05/08 08:27 PM
RapidRobert
yes there is,crack the (4) fan bolts loose before you loosen the fan belt.
[Re: RapidRobert]
#68108
06/05/08 08:43 PM
06/05/08 08:43 PM
Posts: 2,590 Piqua, Ohio
dodgeram440
Piqua, Ohio
That would be the four bolts that hold the fan clutch to the pulley, not the four bolts that hold the fan to the clutch. And if you crack the bolts loose before you loosen the belt, the belt will help keep the pulley from turning.
[Re: RapidRobert]
#68109
06/05/08 08:55 PM
06/05/08 08:55 PM
Posts: 21,831 Kirkland, Washington
Pacnorthcuda
I RE-Learn that almost every time i do that!!!
