Big Block Water Pump Leak? #68095
06/05/08 04:22 PM
06/05/08 04:22 PM
USA
stan1970 Offline OP
stan1970  Offline OP
USA
Hello Moparters..
I'm new to Mopars, so I apologize in advance if I am asking a dumb question...
I have a 440 motor in a Coronet and when the car was sitting for a week recently I noticed a small amount of coolant on the ground. I looked from underneath and could see a tiny stream that had leaked down the lower outlet shaft of the Water Pump housing (and then down on to the lower hose). I could not see above that lower outlet shaft on the pump to see the real source of the leak.
The really strange part is that once I started it up and had it running, the leak stopped. I am pretty certain it will come back though. Seems to just happen when it sits..
Does this sound like it is the Water Pump that is bad (maybe leaking from the weep hole?). Or could it be the actual housing itself that could be leaking? Anyway to determine this?
Also, where are the weep holes on these pumps? Can the Pump be changed while leaving the Water Pump housing on the motor?
Mucho thanks for any feedback.
--Stan
Re: Big Block Water Pump Leak? [Re: stan1970] #68096
06/05/08 04:31 PM
06/05/08 04:31 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Sounds like its from the weep hole. The weep hole is on the lower part of the pumps snout. The pulley commonly covers it up. The pump can be changed without pulling the housing.
Re: Big Block Water Pump Leak? [Re: stan1970] #68097
06/05/08 04:32 PM
06/05/08 04:32 PM
Stan welcome aboard. There are no dumb questions only unasked ones. sounds like a weep hole which is on the underside of the impeller assy which comes out by itself(4 bolts) & the wp housing doesn't need to be touched.
Re: Big Block Water Pump Leak? [Re: RapidRobert] #68098
06/05/08 05:16 PM
06/05/08 05:16 PM
USA
stan1970 Offline OP
stan1970  Offline OP
USA
Hey Thanks for the quick replies. Much appreciated.
I guess I should have included a digital picture of this (seems to be the standard way of doing business nowadays).
In this pic (shot from below) - the wet area above the lower radiator hose -- I guess this must be leading up to the weep hole then?
As for taking out the pump -- the general steps seem to be: loosen up the alternator bracket and remove the belt, pull the fan and fan clutch assembly, pully and then the four water pump bolts? Or am I missing anything there?
Thanks again. The help is much appreciated in getting started.
--Stan
Re: Big Block Water Pump Leak? [Re: stan1970] #68099
06/05/08 05:47 PM
06/05/08 05:47 PM
Cochise County Arizona
SPWC Offline
SPWC  Offline
Exact thing happened to my wagon(Daily Driver). I went on Vacation for 2 weeks and came back,noticed the pump leaking just like youve described. Topped off the radiator,drove it home and it hasnt leaked since!!
I can hear the pump groaning and growling sometimes though. Id say it needs to be replaced,before it leaves me high and dry someday>
Re: Big Block Water Pump Leak? [Re: SPWC] #68100
06/05/08 06:17 PM
06/05/08 06:17 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
B/RB water pump very simple to change. Loosen alternator, remove belts, remove 4 fan bolts, remove 4 pump bolts, rap pump off housing, cleans housing surface, install new gasket and pump in reverse proceedure.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Big Block Water Pump Leak? [Re: MoparforLife] #68101
06/05/08 06:37 PM
06/05/08 06:37 PM
SPWC Offline
SPWC  Offline
What about draining the coolant,isnt that necessary?
Re: Big Block Water Pump Leak? [Re: SPWC] #68102
06/05/08 06:42 PM
06/05/08 06:42 PM
Drain it 1st. Replace with fresh coolant.
Re: Big Block Water Pump Leak? [Re: MoparforLife] #68103
06/05/08 06:44 PM
06/05/08 06:44 PM
USA
stan1970 Offline OP
stan1970  Offline OP
USA
Great info. Thanks a bunch guys!
One last question -- this fan has a fan clutch assembly... How do those things come off (and go on)? This is the first time I've encountered this option.
Much thanks for the help!
--Stan
Re: Big Block Water Pump Leak? [Re: SPWC] #68104
06/05/08 06:55 PM
06/05/08 06:55 PM
Upper Midwest
Upper Midwest
hell it will self drain if you don't.
Re: Big Block Water Pump Leak? [Re: MoparforLife] #68105
06/05/08 08:13 PM
06/05/08 08:13 PM
Re: Big Block Water Pump Leak? [Re: RapidRobert] #68106
06/05/08 08:18 PM
06/05/08 08:18 PM
USA
stan1970 Offline OP
stan1970  Offline OP
USA
Ok, thanks!
What about the fan clutch assembly? Do these things come off/ go back on easily? I haven't encountered one of these before...
Is there any gotchas with that piece (other than the tight space I'm going to have between it and the radiator)?
Thanks!
--Stan
Re: Big Block Water Pump Leak? [Re: stan1970] #68107
06/05/08 08:27 PM
06/05/08 08:27 PM
yes there is,crack the (4) fan bolts loose before you loosen the fan belt.
Re: Big Block Water Pump Leak? [Re: RapidRobert] #68108
06/05/08 08:43 PM
06/05/08 08:43 PM
Piqua, Ohio
dodgeram440 Offline
dodgeram440  Offline
Piqua, Ohio
That would be the four bolts that hold the fan clutch to the pulley, not the four bolts that hold the fan to the clutch. And if you crack the bolts loose before you loosen the belt, the belt will help keep the pulley from turning.
Re: Big Block Water Pump Leak? [Re: RapidRobert] #68109
06/05/08 08:55 PM
06/05/08 08:55 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I RE-Learn that almost every time i do that!!!
