71-74 Rally Clusters #681018
04/26/10 07:07 PM
04/26/10 07:07 PM
Hunt Valley, Maryland
1fastrunner Offline OP
I have a rally cluster in my '71 RR without a clock or tach. I found one that has a tach that I want to add to mine. I'll also have to use the other gauges in the cluster in mine. I'm questioning if I need any other wiring besides the tach wire to make it work? It will be the only item added, but the other ones will be combined and in a new location, will the current wires be long enough?
Thanks,
Re: 71-74 Rally Clusters [Re: 1fastrunner] #681019
04/26/10 09:53 PM
04/26/10 09:53 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
If you have a non tach or clock cluster. You can not just change the gauges over to it. You will need to buy a complete cluster with the tach clock provision.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 71-74 Rally Clusters [Re: 70gtx440dana] #681020
04/26/10 10:03 PM
04/26/10 10:03 PM
That's what I'm planning on buying. I just want to know if my current harness hooked up to my current cluster, without a clock or tach, will work with the addition of a tach wire.
Re: 71-74 Rally Clusters [Re: 1fastrunner] #681021
04/26/10 10:24 PM
04/26/10 10:24 PM
SF Bay Area, CA
charger440sixpak Offline
SF Bay Area, CA
Yep, you just need to add the wiring for the tach.
Re: 71-74 Rally Clusters [Re: charger440sixpak] #681022
04/26/10 10:47 PM
04/26/10 10:47 PM
Mesa, Az
GETX Offline
GETX  Offline
Mesa, Az
Re: 71-74 Rally Clusters [Re: GETX] #681023
04/26/10 10:56 PM
04/26/10 10:56 PM
IL
71383beep Offline
71383beep  Offline
IL
1 more for good measure. A tack or clock cluster and the wiring will bolt in. The tach wire is separate as stated.
'73 GK6 Challenger Rallye - 340 4-Speed
