Offset motor.....centered rear end pinion #680912
04/26/10 06:18 PM
04/26/10 06:18 PM
Manteca, CA
DRJDVM Offline OP
DRJDVM  Offline OP
Manteca, CA
How many of you guys are running the stock offset motor position, but have the rearend pinion dead center (the actual yoke is dead center...same measurement from yoke to flange on each side)??...i.e the yoke not offset to the pass side like the motor......
Other than tunnel clearence, is there any problems in doing that?
Re: Offset motor.....centered rear end pinion [Re: DRJDVM] #680913
04/26/10 11:32 PM
04/26/10 11:32 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Nope, it'll work just fine..
Re: Offset motor.....centered rear end pinion [Re: Bill MeLater] #680914
04/27/10 12:28 AM
04/27/10 12:28 AM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I've been told there should be some offset somewhere so the u-joint needle bearings will rotate. The tail shaft and pinion center line, however need to be parallel. While This page doesn't describe the needle bearing part it does describe the angle requirement pretty good
Re: Offset motor.....centered rear end pinion [Re: DRJDVM] #680915
04/27/10 12:32 AM
04/27/10 12:32 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The yoke actually is offset. If you are referring to the 8 3/4 axle, the 3rd member bolts into the center of the housing. The pinion sits to the right by about 1 3/4 inches. The driveline tunnel is off center as well.
Re: Offset motor.....centered rear end pinion [Re: Kern Dog] #680916
04/30/10 11:19 AM
04/30/10 11:19 AM
Manteca, CA
DRJDVM Offline OP
DRJDVM  Offline OP
Manteca, CA
That page is very helpful....
What I'm talking about is the offset from side to side of the centerlines of the rearend yoke and the crankshaft.... in other words if you drew a straight line throught the crank and to the back of the car...and drew a straight line from the yoke to the front of the car....do they need to totally line up with each other in the horizontal plane......
So the answer is "No"... they just need to be parallel to each other....like the "Vertical Views" A and B on that linked page
Which is what I have...so I should be good....
