Car has Electrical Power but will not turn over #680837
04/26/10 04:41 PM
04/26/10 04:41 PM
fury4speed Offline OP
Car has over 12 volts at the Fuse block , the Fusible link (between the connections) at the Red wire from the firewall plug all have ove r12 volts , turn the Ignition switch on and nothing happens , the dash lights up , oil pressure switch is lit , the Car Started before just fine , any suggestions? thanks.
Re: Car has Electrical Power but will not turn over [Re: fury4speed] #680838
04/26/10 05:04 PM
04/26/10 05:04 PM
(1) need fire @ the "ign" terminal on the starter relay when you turn the key to start (ign2). (2) the "grn" terminal close to it on the same starter relay needs to be grounded when the trans is in park or neutral. need a jumper wire w alligator clips on each end to check (2) and a helper turning the key to "start" as you check for fire w a test light or VOM for (1).
Re: Car has Electrical Power but will not turn over [Re: RapidRobert] #680839
04/26/10 06:11 PM
04/26/10 06:11 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Take a screw driver and arch between the terminals on the starter relay or on the starter solenoid and see what happens.Make sure that the neutral starter switch wire is hooked up.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Car has Electrical Power but will not turn over [Re: MoparforLife] #680840
04/26/10 06:32 PM
04/26/10 06:32 PM
It is a 1968 4 Speed Car , everything worked last week , so the only thing I think might be bad is the Battery has a bad cell and when a load is put on the Battery it does not have enough volts / amps to start unless the starter solenoid decided to go bad , I will check all the suggestions , thanks.
Re: Car has Electrical Power but will not turn over [Re: fury4speed] #680841
04/26/10 06:38 PM
04/26/10 06:38 PM
Upper Midwest
Upper Midwest
In that case make sure that the battery has a good charge and the connections at the battery posts are shiny clean. Remove the cables and scrape both the posts and the cables clean and make sure that they are good and tight
Re: Car has Electrical Power but will not turn over [Re: MoparforLife] #680842
04/26/10 06:52 PM
04/26/10 06:52 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
definitely check the NSS.
Re: Car has Electrical Power but will not turn over [Re: sharpie] #680843
04/26/10 07:37 PM
04/26/10 07:37 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
corrosion/bad contact somewhere..does it crank when u jump the starter relay?
Re: Car has Electrical Power but will not turn over [Re: AARCONV] #680844
04/26/10 07:39 PM
04/26/10 07:39 PM
I will check that tomorow and also the NSS.
Re: Car has Electrical Power but will not turn over [Re: fury4speed] #680845
04/26/10 08:10 PM
04/26/10 08:10 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You don't have nss, I would check for 12 volts at the yellow wire on starter relay, when the key is turned to start.
Re: Car has Electrical Power but will not turn over [Re: buildanother] #680846
04/26/10 09:09 PM
04/26/10 09:09 PM
That was my next Question , when did Chrysler Products start using them on Manual Trans Cars?
Re: Car has Electrical Power but will not turn over [Re: fury4speed] #680847
04/26/10 09:14 PM
04/26/10 09:14 PM
Upper Midwest
Upper Midwest
Go into the car and put your clutch in and the transmission in Reverse.
Re: Car has Electrical Power but will not turn over [Re: MoparforLife] #680848
04/26/10 09:17 PM
04/26/10 09:17 PM
OK , why?
Re: Car has Electrical Power but will not turn over [Re: fury4speed] #680849
04/26/10 11:09 PM
04/26/10 11:09 PM
Upper Midwest
Upper Midwest
Some had a neutral clutch switch but memory escapes me which ones.
Re: Car has Electrical Power but will not turn over [Re: fury4speed] #680850
04/27/10 07:39 AM
04/27/10 07:39 AM
chicagoland,usa
chicagoland,usa
68 does not have it, I believe the 70 model year started with the clutch switches. Maybe even 71.
Re: Car has Electrical Power but will not turn over [Re: fury4speed] #680851
04/27/10 02:12 PM
04/27/10 02:12 PM
Red Bluff, CA
W
WilliamHall Offline
super gas
WilliamHall  Offline
super gas
W
Red Bluff, CA
make sure the starter wire hasn't slightly lodged out of the connection block at the firewall. I just had this happen to me.
