Re: LIFTERS....should I see them turn??
[Re: cornucopia]
#68078
06/05/08 04:01 PM
06/05/08 04:01 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
They could be skidding on the moly, but why risk it? I have always marked the lifters with a Sharpie, and turn the crank 10 full rotations. If I don't see atleast a 1/4 rotation I'll switch a few around till I see the rotation. Then re-moly the face of the lifter once I'm satisfied. HTH's
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: R70RUNNER]
#68083
06/05/08 05:45 PM
06/05/08 05:45 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
HTH's
you should see them all rotate , if not move them around .
what cam are you using ?
[Re: JohnRR]
#68084
06/05/08 06:29 PM
06/05/08 06:29 PM
Posts: 4,150 lewiston, ID
cornucopia
lewiston, ID
HTH's
the cam is an old crane "Blazer 288" vintage 1981. I got it new in the box from a friend of mine for free. the lifters are new 'perfect circle' units...I gooped everything up with GM EOS lube and then dumped a bottle of the red, Comp cam lube on everything for good measure.
I'll pull the rockers and pushrods and swap holes with the lifters and check for any tight ones and try again. thanks for the help, guys!
[Re: cornucopia]
#68085
06/05/08 06:53 PM
06/05/08 06:53 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
light oil is all that should be on the sides of the lifter and the bores that they ride in. Not the sticky lifter to cam lube.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
