Wiring in an accessory electrical outlet
#680628
04/26/10 12:26 PM
04/26/10 12:26 PM
Posts: 4,102 Cochise County Arizona
SPWC
My Truck was ordered from the factory as a Cigarette lighter delete.
I have a TOM TOM GPS unit I would like to run in the vehicle,to see if how much im off on my speedo since changing the tires out. I know the GPS unit might not be 100% accurate,but its pretty darn close.
Id also like to use my Cell Phone Car charger while on the road.
I know these auxillary outlets(similar to cigarette lighter outlets) can be purchased for pretty cheap at places like Walmart.
Whats the best way to wire them into the vehicle?
Re: Wiring in an accessory electrical outlet
[Re: SPWC]
#680629
04/26/10 01:33 PM
04/26/10 01:33 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
just a question... what truck are we talking about ? normally the wiring is already there, since you won't find any assembly plant making a special underdash wiring for cars with deleted options. So I think you need just to get the lighter assembly ( sockets are pretty much universal fit http://cgi.ebay.com/ebaymotors/FORD-PICK...=item1c117f8267 ), fit on the right location and voila! wire will be there waiting for you This wire ( on old cars ) is normally pink wire, sometimes with an splice for any other function with 90º barrel/bullet kind female terminal. Sockets have a variety of disposition. The right one to make a nice plug and play job is a stud on back, but some of them are a prong, some other are wires with spade terminals. The one I posted from ebay should it be the right one to make the plug and play job
[Re: NachoRT74]
#680631
04/26/10 02:16 PM
04/26/10 02:16 PM
SPWC
Sorry for not specifying which truck. Its on my 73 Dodge D200
