Cam bearings required with cam change? #68060
06/05/08 02:54 PM
06/05/08 02:54 PM
Snowing in the north!
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Just a question because I know many who have not
changed their cam bearings with a cam change. I think mine have all of 200 miles (at the most) on
them and I'm considering a lower profile cam.
Re: Cam bearings required with cam change? [Re: Dart 340] #68061
06/05/08 02:58 PM
06/05/08 02:58 PM
Kirkland, Washington
Pacnorthcuda Offline
bout the ONLY time cam bearings are changed is if they are damaged or you are having the block hot tanked. They are lightly loaded and well lubed. Your's are fine
Re: Cam bearings required with cam change? [Re: Pacnorthcuda] #68062
06/05/08 03:52 PM
06/05/08 03:52 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Cam bearings seldom replaced.
Re: Cam bearings required with cam change? [Re: MoparforLife] #68063
06/05/08 04:06 PM
06/05/08 04:06 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Awesome. Would make a change out much easier.
Re: Cam bearings required with cam change? [Re: Dart 340] #68064
06/05/08 06:16 PM
06/05/08 06:16 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Just don't chip them when you remove and replace the cam and you'll be fine.
