Re: Making a diesel from /6 or 22re?
[Re: 70Duster]
#680491
04/26/10 03:51 PM
04/26/10 03:51 PM
Posts: 413 Norway (old world)
Oyvind Mopar
Norway (old world)
/6 has only four main bearings. And, it has a long stroke (OK) but with superlong skinny rods. Really bad for a diesel. If you want to make any sort of power, it is better to use a high quality engine as a base. Best is to use a designed diesel engine, although it is less of an experiment. I have had an Olds Diesel, which is a lowpressure engine, and it still blew headgaskets, even with studs for the heads. Went to M14 allen bolts, OK for a while, then I gave up and quit. The 6.2 GM diesel can break the crank if you start it with start-gas, or if it has a leaky injector. A friend of mine broke the crank, without doing others than a normal start. He hated that car.... I would say a heavy, forged crank is a minimum for a diesel. Please also think about what sort of combustion chamber to work with. A prechamber head from a /6 will require extensive mods, and is hard to make correctly. What is your goal? Thanks!
[Re: Oyvind Mopar]
#680492
04/26/10 05:21 PM
04/26/10 05:21 PM
Posts: 10,713 North Dakota
6PakBee
North Dakota
Consider this, which of the two engines could survive operating under heavy detonation continuously? I would guess neither. Which component would fail first? I am guessing the pistons. Can you get a better piston? If you can what will fail next? I would guess the rods. Can you get a better rod?.....Do you see how this is going? The 5.7L diesel that GM used in the late 70's early 80's used a tremendously beefed up version of the 350 Olds gas engine. Even with that they had durability problems. I'm one to never say never but I don't see a happy ending with this project.
[Re: 74chargr]
#680493
04/26/10 05:35 PM
04/26/10 05:35 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
look up 4BT diesel and install one of those.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#680494
04/26/10 05:51 PM
04/26/10 05:51 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
This really sounds like one of those "What If" deals that is trying to come up with something that hasn't been done before, on a budget and with stuff at hand. There is a 99% failure rate on dreams like this, due to lack of money, time or abilities. Of the stuff that reaches the test phase, I'd guess that the failure rate is still over 50% and by that time the thinker has found out enough to realise that the project is doomed because things that are already built are both cheaper and better. Dreaming is great, but temper it with some knowledge of how the stuff works and if anyone has already littered the path with broken dreams.
[Re: 74chargr]
#680496
04/27/10 10:02 AM
04/27/10 10:02 AM
Posts: 4,041 michigan woods
imfixinmopars426
michigan woods
NO...neither is near as heavy duty as a 350 old diesel. they might be "made" that way,but still will never hold up. a well maintained 350 old diesel is a ok engine,and will run many miles,but many owners drove them a gassers,and they died./6 has no good points for a diesel conversion...maybe a 383?,w/ tons of mods...look at how much more btu's diesel is than gasoline,and transfer that into power,and stress...not good!..ever look at a 7.3 ford,or a cummings??? there is a reason why they weigh a ton! BEEF! and as far as E85,whats the point of this? fuel mileage? power? alky uses much more fuel than gas for same btu's,let alone diesel. so if mileage is the reason...forget it. and as for power,well....use nitro...lol.
[Re: 74chargr]
#680497
04/27/10 10:10 AM
04/27/10 10:10 AM
RodStRace
Chino Valley
Okay, what's cheap? I see you are in the Tacoma area, so I searched the local CL. Hey, the American spirit is built on making something you need with what is at hand, but if you can get something even better cheap, well that's true too. Here are 4 diesel engines complete and running, each for 500 bucks. I doubt you can find anyone to build diesel pistons for the /6 for that, plus compression, fuel system, pump, etc. http://seattle.craigslist.org/tac/cto/1712071769.htmlhttp://seattle.craigslist.org/tac/pts/1710868934.htmlhttp://seattle.craigslist.org/tac/cto/1709780755.htmlhttp://seattle.craigslist.org/sno/cto/1708852207.htmlPlease note that each of these (except the Ford) come with fuel tank, lines, engine cradle, exhaust system, cooling system, electrics, and other support systems that are designed and built to support the engine on diesel. This is already included in the price. In fact, each of these include additional parts that can be sold off to recoup some or all of the purchase price, or be saved for future projects. diesel with generator $300 http://seattle.craigslist.org/tac/grd/1708088083.html
[Re: 74chargr]
#680498
04/27/10 10:14 AM
04/27/10 10:14 AM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
I have a experiment I want to perform. I want to make a diesel from one of these two engines. Which do you think would make a better one? The 22re is Aluminum which I think is not as good a material for a diesel.Since it doesn't retain heat as good it is less desirable? The 22re is easier for me to rebuild and convert because it needs less work for it to happen. The /6 is in need a a bunch of work for the rebuild but I don't think that matters as much as which would make a better diesel. The reason I am asking about these two engines is I already have them. As far as an application it is for a homemade generator.
I saw a /6 diesel at Carlisle a few years ago that IIRC was built by Chrysler. I don't know if it ran but it was complete.
