Bought 72 SE Charger, How do I get rid of the small win #680314
04/25/10 09:34 PM
04/25/10 09:34 PM
Manistee, Michigan.
High Impact Offline OP
Manistee, Michigan.
I just bought a really solid 72 SE Charger and I want to get rid of the small quarter window look. I was told I just have to drill out some spot welds and get rid of the plug incert they used. MY QUESTION IS: How do I entend the drip edge for the chrome molding???
Anybody done this?
Re: Bought 72 SE Charger, How do I get rid of the small win [Re: High Impact] #680315
04/26/10 01:56 AM
04/26/10 01:56 AM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
I haven't done this, but I can tell you that there is indeed a filler plug welded in that needs removed. Didn't look like a big deal to remove, once the top was off. As for the drip edge, I'm guessing you'd have to weld on the additional extension. The additional piece could be cut from just about any 2dr 71-4 B body, or fabricated.
I would also recommend replacing the upper chrome/stainless channel that the weather strip goes in, with one from a 71/2 B-body. Not sure if the 73/4 are the same...but they might be.
