Small Block Cam and Lifter Issues AGAIN #67985
06/05/08 10:26 AM
06/05/08 10:26 AM
Minnesota
FROZEN BOHEMIAN Offline OP
Minnesota
I seem to be another victim of the dreaded hydraulic lifter issue.
My 65 273 235hp has 600 miles on a full rebuild.
I swapped the solid cam for a General Kinetics cam with hydraulic lifters. Now the rockers are loose she is a'knockin and rattling.
I can swap out the lifters quick enough but to what? another set that will fail?
Aside from tearing it apart again for a new solid cam and lifter set, what other options do I have?
solid lifters on the hyd cam? better set of lifters, like anti-pump up?
Re: Small Block Cam and Lifter Issues AGAIN [Re: FROZEN BOHEMIAN] #67986
06/05/08 10:39 AM
06/05/08 10:39 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Did you change out pushrods also?
Tony
70 AARCuda Vitamin C
Re: Small Block Cam and Lifter Issues AGAIN [Re: 70AARcuda] #67987
06/05/08 10:54 AM
06/05/08 10:54 AM
Minnesota
Minnesota
YES pushrods are different length between solids and hyd. However the pushrods do not have holes in the ends.
As part of this stressful adventure I noticed the oil pressure is lower than normal when hot. Hot oil pressure is 40 at 2000rpm.
Re: Small Block Cam and Lifter Issues AGAIN [Re: FROZEN BOHEMIAN] #67988
06/05/08 11:01 AM
06/05/08 11:01 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I would look at the cam.I bet you lost a lobe or 2 and the shrapnal went through the oil pump causing your low oil pressure. Been there done that!Hope you have better luck than I did!Good luck!
Re: Small Block Cam and Lifter Issues AGAIN [Re: Dcuda69] #67989
06/05/08 11:50 AM
06/05/08 11:50 AM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Assuming you find wiped lobes/lifters...next time, with the intake off and everything mocked up, turn the engine over and make sure the lifters are rotating. If they aren't, it will do it again.
Over the last few years I've seen several sets of hydraulic lifters that had insufficient crown and would not rotate....pair that up with the additive-depleted modern oils, which is a whole other topic, and you've got a recepie for a mess.
Cams have been made basically the same for eons, but lifters have not, unfortunately.
Rich H.
Esse Quam Videri
Re: Small Block Cam and Lifter Issues AGAIN [Re: Dcuda69] #67990
06/05/08 12:01 PM
06/05/08 12:01 PM
Minnesota
Minnesota
say it aint so..
I did pull a couple of lifters..
look nice no wear but I could push the middle in by hand on one.
ran the car with valve covers off, all the rockers seem to actuate.
idle is good, after adjusting all the valves but after running it around a bit the noise returns and the rockers are loose again.
I do need to check lock nuts to see if they are backing off, but they seem tight.
would bad, collapsed lifters affect oil pressure?
Re: Small Block Cam and Lifter Issues AGAIN [Re: ZIPPY] #67991
06/06/08 12:07 AM
06/06/08 12:07 AM
Wisconsin
69 Road Chicken Offline
Wisconsin
I assume you mean with the starter and not by hand? Just watch for them to spin?
Re: Small Block Cam and Lifter Issues AGAIN [Re: FROZEN BOHEMIAN] #67992
06/06/08 12:18 AM
06/06/08 12:18 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
say it aint so..
It won't wipe them all at once.
At the very least, pull every one that you've had to re adjust, but I'd pull them all.
From what has been described. I have almost no doubt you are in the middle of a cam/lifter failure, and just haven't found it yet.
