Re: Small Block Cam and Lifter Issues AGAIN
[Re: FROZEN BOHEMIAN]
#67986
06/05/08 10:39 AM
06/05/08 10:39 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
Did you change out pushrods also?
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Dcuda69]
#67989
06/05/08 11:50 AM
06/05/08 11:50 AM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
Assuming you find wiped lobes/lifters...next time, with the intake off and everything mocked up, turn the engine over and make sure the lifters are rotating. If they aren't, it will do it again.
Over the last few years I've seen several sets of hydraulic lifters that had insufficient crown and would not rotate....pair that up with the additive-depleted modern oils, which is a whole other topic, and you've got a recepie for a mess.
Cams have been made basically the same for eons, but lifters have not, unfortunately.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#67991
06/06/08 12:07 AM
06/06/08 12:07 AM
Posts: 50 Wisconsin
69 Road Chicken
Wisconsin
I assume you mean with the starter and not by hand? Just watch for them to spin?
#67992
06/06/08 12:18 AM
06/06/08 12:18 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
say it aint so.. I did pull a couple of lifters..
It won't wipe them all at once.
At the very least, pull every one that you've had to re adjust, but I'd pull them all.
From what has been described. I have almost no doubt you are in the middle of a cam/lifter failure, and just haven't found it yet.
