How much Gear oil goes into 8 3/4? #67979
06/05/08 10:17 AM
06/05/08 10:17 AM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
How much? Diff is sure grip if that matters. Thanks
Re: How much Gear oil goes into 8 3/4? [Re: 68Bullit] #67980
06/05/08 10:52 AM
06/05/08 10:52 AM
Retired now in Tennessee
Chi_Town_Runner Offline
This is what my '68 Service Manual says:
2 pints
However, I think the old rule of thumb was to fill the rear end so when you place your finger into the fill hole and bend it at the first knuckle you should just be touching the lubricant. I know that's what I do.
Hope this helps
Frank
Re: How much Gear oil goes into 8 3/4? [Re: Chi_Town_Runner] #67981
06/05/08 11:01 AM
06/05/08 11:01 AM
Anywhere the British Secret Se...
Moonraker Offline
Moonraker  Offline
2 pints
Hope this helps
Frank
WOW! I filled my 8.75 up and it took almost 2 1/2 quarts! If you use friction modifier add it first then add the lube until it begins to come out of the fill hole on the side. Easy.
Re: How much Gear oil goes into 8 3/4? [Re: Moonraker] #67982
06/05/08 11:43 AM
06/05/08 11:43 AM
Kirkland, Washington
Pacnorthcuda Offline
Its right around 2.5 QUARTS--definately not pints.
Re: How much Gear oil goes into 8 3/4? [Re: Moonraker] #67983
06/06/08 01:11 AM
06/06/08 01:11 AM
...If you use friction modifier add it first then add the lube until it begins to come out of the fill hole on the side. Easy.
That's exactly how I do mine.
Re: How much Gear oil goes into 8 3/4? #67984
06/06/08 07:33 AM
06/06/08 07:33 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
Just filled mine last night. It took 2 1/2 quarts with a spool in it.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
