Help hanging glass doors please
#679654
04/25/10 07:21 AM
04/25/10 07:21 AM
Posts: 214 canada,NB
jb15
canada,NB
in the process of making my own fiberglass doors ,have one almost finished, hoping someone would have some pic's of some lite,homemade hinges. or the door and hinges mounted to car. If I have a picture, I can make it, (I hope). . Thanks, Jim..
Re: Help hanging glass doors please
[Re: sam64]
#679656
04/25/10 09:58 AM
04/25/10 09:58 AM
Posts: 1,402 State of Corruption
camdog440
State of Corruption
You could just buy this from www.Jerrybickel.comProduct Description: The JBRC Door Hinge Kit is designed to be used with after market light-weight fiberglass doors. This kit is constructed of 4130 moly tubing and mounting plates. Our design makes removing and installing of doors easy by lift-off type construction with a unique safety stop which allows the door to be removed only when in an open position. Includes all necessary mounting hardware.
[Re: camdog440]
#679657
04/25/10 10:13 AM
04/25/10 10:13 AM
jb15
canada,NB
$160 U.S??by the time I get those up north they'll cost over $200 ,thought someone might have tryed to make there own light ones... I'll get'er fingered out... thanks, Jim
[Re: jb15]
#679658
04/25/10 10:55 AM
04/25/10 10:55 AM
Posts: 2,118 Byron, NY
W.I.N. Racing
Byron, NY
Let me help you out here....
"If I have a picture, I can make it" = ?????
[Re: go green]
#679663
04/25/10 02:14 PM
04/25/10 02:14 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
The door jams are not parallel to the door jam . The bottom hinge pivot has to be around 3/4" longer on the bottom in order to have the door open level.
Just look at your stock hinge's and you will see what I mean.
The RJ or Bickel stuff all have same mount to pivot distance .
I will take a few pictures and help you out.
I've used those JB hinges on lots of stock bodied cars in the past...on the door the pivots need to be on the same verticle plain...the tubes that attach to the body end up being different lengths.Plus with the JB it positive retains the door and requires no pins....just open....lift and remove....simple but perfect hinge.
[Re: go green]
#679665
04/25/10 03:42 PM
04/25/10 03:42 PM
jb15
canada,NB
thanks again go green, good pics. awesome car dude ,would love to be turbo charged, Jim.
[Re: go green]
#679666
04/26/10 09:50 AM
04/26/10 09:50 AM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Go Green good design so the mount on the body is solid/doesn't move. But the door half IS adjustable correct? Thanks Don
[Re: go green]
#679668
04/26/10 11:15 AM
04/26/10 11:15 AM
Chassisman
Chowchilla,ca
On the car there are the factory holes that take 3/8" bolts where the original hinge mounts . The stand off tubes that encase the 3/8" bolts are .750" x .065" tube .There plenty of room between the bolt and the inside of the standoff tube to adjust the door up or down . So the door receiver hinges are non adjustable but the car mounted pins stands are.
Thats almost exactly the way I did them....I would make a plate from sheet CM that would go into the factory holes...alot of times I'd make new nut plates from aluminum f wieght was an issue. I like the idea tying them together with one long tube.
