Tire size question for a Dart #679555
04/24/10 11:39 PM
04/24/10 11:39 PM
corpus christi tex
Cheatham Offline OP
Cheatham  Offline OP
corpus christi tex
Im wanting a rear tire preferably as tall as possible. i have a stock width rear and stock width frame rails and 10in wide wheel,currently mounted is a 29x10 section width 13in. my concern is if i were to go with a tire with a section width of 14-14.5 in is will it fit? i know it will be close but is it a safe close? right now i have an 1 1/4 from sidewall to frame. outside of tire is no clearance issuse, it on a 73 Dart.id like to get about 96-99in of roll out, i see a tire with 103in but that maybe too much, i see Hoosier has a 29.5x30.5 with a sec. of 13in and 96in rollout. i know some of you guys got some good info on this.
Re: Another tire Q [Re: Cheatham] #679556
04/25/10 07:24 PM
04/25/10 07:24 PM
corpus christi tex
Cheatham Offline OP
Cheatham  Offline OP
corpus christi tex
Anybody????
Re: Another tire Q [Re: Cheatham] #679557
04/26/10 04:14 PM
04/26/10 04:14 PM
corpus christi tex
Cheatham Offline OP
Cheatham  Offline OP
corpus christi tex
Anybody????
Re: Another tire Q [Re: Cheatham] #679558
04/26/10 05:51 PM
04/26/10 05:51 PM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
bump..... I've got a mini tub'd 69 dart and the maximum section width I can get away w/ it probably 14"...... I run a 28x11.5(12.9"section) M/T and they rub a little if I turn off the track too fast
Re: Another tire Q [Re: StripeHOG] #679559
04/26/10 06:52 PM
04/26/10 06:52 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Can you post some pics of your rear/tires and 1/4's so we can see what your talking about??
I have a 72 duster with 8 3/4,stock leafs in the stock location. I have 15x8 rims with 28x11.5 QTP's. My tires did rub the leafs a little,so I put on a 1" wheel spacers and fixed that problem.
If I had gone with a 10" rims,I think I could of went with a wider tire. I think you will be pushing the limit on 14" or 14.5" wide. just my
Re: Tire size question for a Dart [Re: Cheatham] #679560
04/27/10 11:03 PM
04/27/10 11:03 PM
corpus christi tex
Cheatham Offline OP
Cheatham  Offline OP
corpus christi tex
theres got to be more Darts with a good size slick with specs similar to mine.
