How to tell if axle bearings are OK or replace? #679287
04/24/10 08:13 PM
04/24/10 08:13 PM
Conn.
b5 69 Offline OP
b5 69  Offline OP
Conn.
Is there a way to check if axle bearings are still good or need to be replaced? I have the axles out of the car. Do bad bearings make noise or vibrations when driving. Since I have them out now would be the time to replace if their bad. I have been chasing a vibration. thanks.
Re: How to tell if axle bearings are OK or replace? [Re: b5 69] #679288
04/24/10 08:28 PM
04/24/10 08:28 PM
NJ
440challenger Offline
NJ
good question. Also whats the best way to set the end play? is there a spec?
Re: How to tell if axle bearings are OK or replace? [Re: 440challenger] #679289
04/24/10 10:12 PM
04/24/10 10:12 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
The bearing will "roar" when they go bad. We had one in a 73 Dodge that got water in it and basically rusted out. The bearing should spin freely and cleanly as a front wheel bearing. They are lubed with grease and not the gear lube in the rear, so both the inner and outer seals must be good to keep the bearing sealed. On an 8-3/4 the spec I have for 68 model year is 0.013"-0.023" end play which is adjusted by the spanner on the passenger side of the rear and locked by a clip mounted to one of the backing plate studs.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: How to tell if axle bearings are OK or replace? [Re: Dads426] #679290
04/24/10 10:32 PM
04/24/10 10:32 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
And trust me, you'll change them b4 they fail completely; you won't be able to stand the noise. DAMHIK
Re: How to tell if axle bearings are OK or replace? [Re: 440challenger] #679291
04/24/10 11:02 PM
04/24/10 11:02 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
The archieve is your friend. http://www.moparts.org/Tech/Archive/axle/12.html
Re: How to tell if axle bearings are OK or replace? [Re: MoparforLife] #679292
04/24/10 11:17 PM
04/24/10 11:17 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
If you can't remember changing them, just change them. I had a scare on a trip to Los Angeles. Started to make noise. Got mine from Dr Diff. Front and rear. I got the "green" ones.
Re: How to tell if axle bearings are OK or replace? [Re: DennisH ] #679293
04/25/10 05:13 PM
04/25/10 05:13 PM
Conn.
b5 69 Offline OP
b5 69  Offline OP
Conn.
Thanks for the responses. Maybe I should just change them, that way Ill know their good. Could anybody give me a quick run down on how to do it. I know I need to use a cut off wheel on something And then get the old bearing pressed off and new green bearing pressed on? Is this correct? Any help would be appreciated. Thanks.
Re: How to tell if axle bearings are OK or replace? [Re: b5 69] #679294
04/26/10 11:22 AM
04/26/10 11:22 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Yes you will need to cut the old ones off. On an 8 3/4 you use side cutters like for a cotter pin to open the outer bearing cage, then cut a notch in the inner race with a grinder to make room to remove the rollers one by one. Then the outer race and bearing cage can come off. Then you use the cutoff wheel to cut down the inner race almost down to the axle. One shot with a hammer and chisel will split it. You also use the chisel to notch the pressed on collar in a few places so it expands and will slip off. Notch it parallel to the length of the axle shaft.
The green bearings don't use the stock end play adjusters.
Re: How to tell if axle bearings are OK or replace? [Re: Sixpak] #679295
04/26/10 03:01 PM
04/26/10 03:01 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
If you have never done it before you are in for a treat. Multiply the time allocated by 4 and you might be close. It is a real PITA. I actually like using a Dremel with the smaller reinforced cutoff wheels as it gets closer to the "cheek" of the axle when cutting the race and splits easier. It is hell on a Dremel though...
If this is a street car you might want to get some opinions on using the "green" bearings. They aren't meant for cornering so you might be repeating this process. It depends on how much you drive it (I wouldn't use them on a street only car).
Re: How to tell if axle bearings are OK or replace? [Re: Dads426] #679296
04/28/10 05:52 PM
04/28/10 05:52 PM
Conn.
b5 69 Offline OP
b5 69  Offline OP
Conn.
Yes it's a street car, 8 3/4" rear. Are the original style bearings still available? Seems like everybody is using the green bearings for replacements. I do know that some have concerns about lateral forces. Can I still get the original style bearing?
Re: How to tell if axle bearings are OK or replace? [Re: b5 69] #679297
04/28/10 11:32 PM
04/28/10 11:32 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I just got mine done with stock bearings a few months ago
Re: How to tell if axle bearings are OK or replace? [Re: b5 69] #679298
04/29/10 12:13 AM
04/29/10 12:13 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The new Timken tapered bearings ARE still available for about $50 each. Knock offs can be had for abouyt $36. These are NorCal prices.
Re: How to tell if axle bearings are OK or replace? [Re: Kern Dog] #679299
04/30/10 06:12 PM
04/30/10 06:12 PM
NH
Fastback67 Offline
Fastback67  Offline
NH
I just cleaned and repacked my old originals a little while back.
Re: How to tell if axle bearings are OK or replace? [Re: b5 69] #679300
04/30/10 07:18 PM
04/30/10 07:18 PM
the oe tapered ones do get loose in the race. If yours NEED replacement I would get some new tapered Timkens rather than the greens
Re: How to tell if axle bearings are OK or replace? [Re: RapidRobert] #679301
04/30/10 08:58 PM
04/30/10 08:58 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
New adjusters are not available, so that's why new axles have Green bearings installed and are marketed as being better since they don't require adjustment.
Re: How to tell if axle bearings are OK or replace? [Re: 375inStroke] #679302
05/01/10 09:01 AM
05/01/10 09:01 AM
NH
Fastback67 Offline
Fastback67  Offline
NH
Honestly, I have never understood the logic behind the adjuster argument... What's so difficult about adjusting a bearing? Especially on the rear... I mean lets face it, there's only the one!
It's a piece of cake...
Re: How to tell if axle bearings are OK or replace? [Re: Fastback67] #679303
05/01/10 10:30 AM
05/01/10 10:30 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
In my car it sounded like I was driving over the steel grating of a draw bridge- or rumble strips. Very attention demanding growl.
Keep old mopars alive.
Re: How to tell if axle bearings are OK or replace? [Re: 2boltmain] #679304
05/01/10 10:33 AM
05/01/10 10:33 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
If in doubt change them out...
Re: How to tell if axle bearings are OK or replace? [Re: AARCONV] #679305
05/01/10 02:02 PM
05/01/10 02:02 PM
PA
U
unclemike Offline
unclemike  Offline
U
PA
What others have said about using the Green bearing on the street they don't like lateral loads very much. The inner and outer seals are or were available last time I looked just be careful and save your retainers.
Has anybody packed their wheel bearings with synthetic grease and do the seals hold up?
